425 Magnum 4x4 sitting up for awhile - Polaris ATV Forum
post #1 of 4 (permalink) Old 05-22-2019, 06:04 PM Thread Starter
pintech's Avatar
My brother bought this 425 Magnum new in 1996. He passed away a couple years ago, but it has been sitting in the shed for a few years before he got sick.
I wanted to get it out and get it running again. I cleaned the carb and put a new fuel pump on it and it started up and is running real good.
I changed the oil and filter. I'm going flush and replace antifreeze.
What else do I need to check and replace to make it reliable?
Thanks for the help and this forum,
Scott
pintech is offline
post #2 of 4 (permalink) Old 05-22-2019, 06:22 PM
stave7119's Avatar
Sorry about your brother....Lets see what we can do to help you. The only other things I can think of off hand would be new spark plug and change transmission oil. If this is a 4x4 you will want to look at the rear differential oil and front hub oils too. I am guessing that you already checked the obvious things like air filter, wheel bearings and tie rod ends. So if everything else checks out go ride!
Hers: 2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. QSC Clutch Kit, Hand Warmers
2001 Magnum 325 Warn winch and Moose 60" plow
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 4 (permalink) Old 05-22-2019, 06:38 PM Thread Starter
pintech's Avatar
Thanks for the reply stave7119,
I,m going to replace all the fluids and lubricants that is changeable.
Is there any way to make sure the coolant is circulating? That was one thing I was concerned about.
It only has about 1000 miles on it and everything seems tight.
Thanks Again
pintech is offline
post #4 of 4 (permalink) Old 05-23-2019, 04:01 PM
stave7119's Avatar
About the only way to be sure is by temperature. Get a non contact thermometer and start the engine. Temp should climb when you check the engine but be lower on the radiator. Let it idle and feel the radiator hoses. Once the thermostat opens both the hoses should feel the same. Leave it idle and keep checking the temp. Around 205 degrees or so the fan should come on and the temp should go down to around 160-180 and start the process over.
VIN - Sportsman 500 or 500 HO? das86turbo ATV Repair and Maintenance 7 01-02-2019 06:58 AM
95 xplorer transmission case Posdeer ATV General Discussion 3 01-16-2018 04:21 AM
