2006 330 Magnum key switch issues. - Polaris ATV Forum
post #1 of 10 (permalink) Old 10-08-2019, 08:53 AM Thread Starter
Hwebman's Avatar
I just replaced the key switch and now when I turn the key the motor starts but when I let go it and the key goes back into run position the key is not energized and kills the motor? what am I missing?
Please help
Hwebman is offline
post #2 of 10 (permalink) Old 10-08-2019, 10:30 AM
stave7119's Avatar
Probably a bad switch. No matter where you got it, new doesn't always mean good. It happens sometimes.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 10 (permalink) Old 10-08-2019, 10:57 AM Thread Starter
Hwebman's Avatar
I just ordered another one just like you said you never know? seems like it is more though. When I bought it the previous owner had used a screwdriver to start it by turning it and then pull starting it. I put the new key switch on it and it started right away but when the spring pulled the key back to the on position ...
no power and the display went ff etc..?
Hwebman is offline
post #4 of 10 (permalink) Old 10-08-2019, 01:02 PM
You need to check to see if you loose power on the red/blk wire when the key returns to the 'on' position - loss of power means faulty switch.
latebird is offline
post #5 of 10 (permalink) Old 10-08-2019, 01:09 PM Thread Starter
Hwebman's Avatar
OkAY I did and you are right, I think ? When I turn the key it starts and if I jiggle the wires to the key switch it keeps running and if I jiggle it again it turns off. I think it is in the male plug going into the new switch ? where can I get a new male plug like that? Thanks to you guys we have some progress and still on the hunt for the loose wire?
Hwebman is offline
post #6 of 10 (permalink) Old 10-08-2019, 01:17 PM Thread Starter
Hwebman's Avatar
Okay also I have found several pigtails harnesses with a 6 pin connector but I only have four wires going into mine? I'm confused about that as well
Hwebman is offline
post #7 of 10 (permalink) Old 10-08-2019, 01:20 PM
You should have a 6 pin switch and a 6 pin plug, but only 4 pins are used
latebird is offline
post #8 of 10 (permalink) Old 10-08-2019, 01:54 PM Thread Starter
Hwebman's Avatar
Yes sir you are correct, I see that now.
Hwebman is offline
post #9 of 10 (permalink) Old 10-09-2019, 12:58 PM Thread Starter
Hwebman's Avatar
Okay, I found out that the 6 position harness was just too wallowed out to make a secure connection to the new switch, so I ordered an new harness and will rewire it when it arrives to see if it will repair it. Thank you everyone for the help I truly appreciate it!!!!
Hwebman is offline
post #10 of 10 (permalink) Old 10-09-2019, 01:20 PM
stave7119's Avatar
You my friend are a glutton for punishment! To rewire the entire bike is gonna be a big job. It is the correct way to do it I suppose since the machine is almost 20 years old. I found a used harness and stole the plug I needed for a headlight. Still have the rest of it laying around the shop.
