I have a 330 magnum that belongs to my neighbor. It starts and idles OK.
It doesn't want to Run right under load or at full throttle. I took the air box and air filter off, and If you put your hand over the intake while it is running and restrict the air flow ( I think this richens it up) it seems to run better.
I took the crb off after reading all the posts thinking the carb was dirty.
It is clean thru out.
The rubber diaphragm on the top of the carb?? what is its function???
If it would have a pin hole leak would this cause the problem??
I sure could use some help here.
thanks
thanks
