99 425 magnum - Polaris ATV Forum
post #1 of 5 (permalink) Old 04-12-2012, 03:10 PM Thread Starter
butch5875's Avatar
99 425 magnum
I'm new here- Thanks for any help I have a 425 magnum that will go into reverse and low forward. It rinds when trying to put in high forward. Any guidance on adjustment ?
butch5875 is offline
post #2 of 5 (permalink) Old 04-12-2012, 03:47 PM
Bruce! is offline
post #3 of 5 (permalink) Old 04-12-2012, 03:50 PM Thread Starter
butch5875's Avatar
thanks
post #4 of 5 (permalink) Old 04-12-2012, 04:18 PM
Cal3bCart3r's Avatar
u can try adjusting the shifter linkage that goes from the shifter to the transmission.... u have to turn some bolts and it will extend the rod. But if you do it too much it will grind going into reverse. So just turn it like twice then crank wheeler and put in high and see what it does. real simple!
1997 Polaris Magnum 425 4x4.
2 tractor lights mounted above low beams.
Winch with winch button by steering column.
27" Law skinnies all around w/ ITP SS108 wheels.
2" RubberDownCustoms lift.
Red neon, Boss atv audio tube, and Snork'd.
Gleen plastics, red racks: The Grinch
Team Too-Broke
http://www.youtube.com/calebcarter22
Cal3bCart3r is offline
post #5 of 5 (permalink) Old 04-13-2012, 09:56 AM
put tranny in nuetral , adjust rod ends so they go into shifter and tranny perfectly straight, also check ends for wear, if they are sloppy,replace them
Russ C is offline
