2000 325 Magnum carb specs? - Polaris ATV Forum
post #1 of 6 (permalink) Old 04-14-2012, 03:45 AM Thread Starter
fishdoktor's Avatar
Question 2000 325 Magnum carb specs?
Hello all, just bought a 325 mag only runs on choke, been sitting 2 years. I have the body off and will pull the cv carb 2 day. I have the jet #'s from parts pit, but I'm wondering if I should change any of the jet sizes to make it run better while I'm in there. Any info will be appreciated, new to these cv carbs. Thanks.
fishdoktor is offline
post #2 of 6 (permalink) Old 04-14-2012, 04:53 AM
Bruce! is offline
post #3 of 6 (permalink) Old 04-14-2012, 07:45 AM
jets should be fine, just remove them and make sure to get them clean, especially the small pilot jet down in the hole, it has very small openings which are easily plugged, make sure you can blow thru it easily with your mouth when yur done, did you get a new needle and seat? if so change it, did you dump old gas from tank?, pilot screw on bottom of carb should be set at 2.5 turns out. holler if you have questions
Russ C is offline
post #4 of 6 (permalink) Old 04-15-2012, 05:19 AM Thread Starter
fishdoktor's Avatar
Will do
Thanks Russ, I will do all that, just wondering if any improvements can be made.
post #5 of 6 (permalink) Old 04-16-2012, 06:57 AM
macka's Avatar
Yea, you can run about 1/8-1/4 turn richer on the fuel screw. Improves the mid and top range.
Went for my routine checkup today and everything seemed to be going fine until he stuck his index finger up my butt! Do you think I should change dentists?
macka is offline
post #6 of 6 (permalink) Old 04-21-2012, 04:03 AM Thread Starter
fishdoktor's Avatar
Vibration?
Followed your advice, all jets were clogged. Runs great now but at idle the bars shake like a dog..........you know. Will adjusting the idle screw take that out? Also, does the trans and front and rear diffs take the same oil? Thanks again.
2000 magnum 325 4x4 specs jt269 Polaris Magnum 3 10-11-2012 07:24 PM
325 magnum help {rod specs} QZ87 ATV Repair and Maintenance 8 02-04-2011 07:33 PM
2000 325 Magnum carb question carey965 ATV Repair and Maintenance 8 08-25-2010 05:10 AM
95 425 magnum carb specs? devbrenner ATV Repair and Maintenance 2 05-24-2010 10:21 AM
carb specs ccaboc ATV Repair and Maintenance 1 12-08-2009 03:36 PM
