96 Magnum 425 4x4 electric start issue - Polaris ATV Forum
post #1 of 9 (permalink) Old 10-09-2015, 01:07 AM Thread Starter
Sch37's Avatar
I got a new battery & solenoid & only way I can start it is by jumping the solenoid. Pull start has no guts in it. Fires right up jumping the solenoid & it's the 2nd solenoid I tried & no clicking or anything from it
Sch37 is offline
post #2 of 9 (permalink) Old 10-09-2015, 10:36 AM
Dragnslyr_FOOL's Avatar
Bad start button?
'95 Magnum 425 (Green) sold 11/13
'97 Magnum 425 (Red)
Dragnslyr_FOOL is offline
post #3 of 9 (permalink) Old 10-09-2015, 01:55 PM Thread Starter
Sch37's Avatar
If I wire the small red & white wire to the hot side of the solenoid ( power to only one side of solenoid, other side nothing) my indicator light comes on when start button pushed but starter won't turn. Jumped a wire from indicator light to starter side of solenoid & starter ingages but slowly while the start button in pushed.
Sch37 is offline
post #4 of 9 (permalink) Old 10-09-2015, 03:15 PM
hatzie's Avatar
There's no power to the start wire but the solenoid trips when you jumper it.
Bad start button or damaged start wire.
From orbit on my Android.
hatzie is offline
post #5 of 9 (permalink) Old 10-10-2015, 08:41 AM Thread Starter
Sch37's Avatar
I'm going to look into the wireing & see what's going on when I get a chance
Sch37 is offline
post #6 of 9 (permalink) Old 10-10-2015, 02:01 PM Thread Starter
Sch37's Avatar
All wires look good from solenoid to switch. I jumped my start button directly to my solenoid & it fires right up but my indicator light stays on constant like this. Is there a box that the switches run to that could be bad? Could it be wired like this, runs & stops with key & run/stop buttons.puzzling only start switch isn't working when wired as it was but except for lights cause I have none & haven't checked that .
Sch37 is offline
post #7 of 9 (permalink) Old 10-11-2015, 11:21 AM
hatzie's Avatar
My first guess is the START button has had the radish.
Did you ohm out the wire from the start button to the solenoid?
Do you get volts when you hook a meter from the start wire on the solenoid to a ground and press the start button?
This wiring diagram may help...
hatzie is offline
post #8 of 9 (permalink) Old 10-11-2015, 11:33 AM
islandbuoy6x6's Avatar
The answer is right there in your post. By jumping the start button and it starts. Switch, wire, connections in this circuit. Just because something electrical looks good doesn't mean it is.
islandbuoy6x6 is offline
post #9 of 9 (permalink) Old 10-13-2015, 08:08 AM Thread Starter
Sch37's Avatar
Thanks for the diagram. When I get more time I'll double check all the wires & see if I can't track this down
Sch37 is offline
2006 Predator 90 electric start issue? msmccabe Polaris Predator 7 02-19-2015 02:09 PM
polaris explorer 500 electric start issue Chris_Jenson ATV General Discussion 2 10-07-2014 09:03 PM
2002 Magnum 325 - Electric Start Snodiva Polaris Magnum 3 06-10-2012 06:29 PM
Electric start issue spidey Polaris Sportsman 8 11-20-2011 06:09 PM
Magnum Electric Start not working 2000vikings ATV Repair and Maintenance 9 03-18-2010 03:11 PM
