425 Magnum-2 issues - Polaris ATV Forum
post #1 of 3 (permalink) Old 10-17-2015, 08:15 AM Thread Starter
Slow Poke's Avatar
425 Magnum-2 issues
I have a 96 or 97 model 425 2WD. It is in good condition, and I have owned if for about 12 years. I recently rebuilt the carb and replaced the fuel pump. The engine starts very easily, but under large throttle openings, it runs lean. I covered part of he snorkel opening (about 20%), and it runs very well. It idles and accelerates and runs on top end, too. I have checked out the entire intake system and don't see anything wrong. All connections are good, the filter mount isn't broken. I can't understand why it is running lean.
Also, when it's idling, it will die for no reason, and then it starts up instantly. Idle is smooth, with no surging. Every time it dies, it restarts immediately with no hesitation.
Any ideas?
Slow Poke is offline
post #2 of 3 (permalink) Old 10-17-2015, 09:13 AM
jgue498's Avatar
I'd check for carb boot or other intake leaks. Tiny cracks can lean out the mixture quick. If that doesn't pan out, then make sure the carb slide is working properly, that controls the lower mid to upper throttle, like 2/3rds of it all. Luck!
1998 Sportsman 500 - 4789 miles
Front/Rear 18W-4 inch solid metal CREE LED Floods
Polaris 8" Rear Rack Extender
ODI Rogue 130mm grips
12.5" Kenda BearClaws on rears
2010 Sportsman 500 HO - 1417 miles 189hrs
Tamarack 10" Footpegs
Polaris Front brush guard - bumper
Wants BearClaw HTRs for Christmas!
OPT is here: http://atvconnection.com/forums/pola...vs-ask-expert/
jgue498 is offline
post #3 of 3 (permalink) Old 10-17-2015, 12:02 PM Thread Starter
Slow Poke's Avatar
The slide is good. I checked it out carefully when I rebuilt the carb. But now it won't start, so whatever was causing it to die and then start back up immediately is evidently done now.
Uggggghhhhhhhhh!!!!!! I just got it all put back together, too.......getting really tired of this.
01 Magnum 325 issues basementbuilt Polaris Magnum 7 02-18-2015 06:34 PM
96 magnum 425 4x4 issues oklahoma whitetail slayer Polaris Magnum 9 02-02-2014 10:29 AM
Magnum 500 4x4 issues.... camaro87 ATV Repair and Maintenance 5 03-17-2013 01:59 PM
Magnum 325 issues Jkp07 ATV Repair and Maintenance 2 01-23-2013 12:52 PM
95 Magnum 425 issues Spitfire79 ATV Repair and Maintenance 14 03-24-2011 09:25 AM
