08 outlaw 50 lots of fumes in air box - Polaris ATV Forum
post #1 of 7 (permalink) Old 04-18-2019, 03:35 PM Thread Starter
Tiderencel's Avatar
So kids ran it out of gas at the end of last year, put diesel in it and ran it till it stopped. Cleaned all that out, cleaned carb, changed sprak plug and fuel filter. Got it running again but wouldn't start without full throttle. Shortly after the cdi went out, changed that did a valve adj and cleaned carb again at the same time. Got it going but still had to be on the throttle feathering it to start. Once warmed up it would idle fine. But then weeks later started to die out and one day not start. Did a carb kit and cleaned gas tank and changed fuel and air filter . Started up ran great for 2mins then died. Noticed lots of fumes and some water in the air box, pulled the hose going in the box and was able to get started with play of choke and throttle but got it to idle and tuned ok. But when you put the tube from the oil separator back kills it. Hose from the crankcase has the fumes come through it. Lots of milky oil in the hoses and separator I tried cleaning out. Oil in engine seems ok not milky. Wondering if I did the valves correctly or if my rings are going bad to put that much into the crankcase? Or any other thoughts? Hoping someone has crossed the bridge before as I'm out of ideas.
New to the group even though I've stocked them for a few years now working on little girl's 50 and my 700. Great site and help thank you guys.
Tiderencel is offline
post #2 of 7 (permalink) Old 04-19-2019, 09:57 AM
Change the oil - if the gas is left turned on, the fuel can overflow the carb and fill the crankcase with gas. Milky oil usually indicates oil emulsified with water (some what normal in vent lines) - if the oil is contaminated with gas, then as the engine heats, the vapor is drawn into the intake and it runs rich (can cause a low idle) - being flooded is indicated by having to hold the throttle open to get it stated -
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #3 of 7 (permalink) Old 04-23-2019, 12:19 AM Thread Starter
Tiderencel's Avatar
Thank you late bird. Changed the oil yesterday which wow how easy it is to forget something simple like that, oil was nasty. So just after doing it fumes still there but able to start and get it to idle with choke at full, can't move it or will die. Throttle screw is in all the way which I find weird but if I come out on that will die also. I really don't know if I have the adj screw on the throttle cable adj right or not. Play in the stick seems to be right but still wondering. Any thoughts out there?
post #4 of 7 (permalink) Old 04-23-2019, 06:30 AM
I'm guessing you still have a problem in the carb - typically if you open the throttle and it bogs, it's getting all air and no gas
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
latebird is offline
post #5 of 7 (permalink) Old 05-22-2019, 06:38 PM
biz4two's Avatar
Arrow
Agree that the carb sounds like it is still the issue. Need to focus on the idle circuit of the carb. So, you said, you cleaned the carb. But, how did you go about cleaning it?? Did you soak it in carb cleaner and spray it? Or did you use an ultrasonic cleaner?? Or??
biz
Took delivery on February 4, 2011
Sold 2011 Sportsman 850 Touring EPS -- Mine
Sold 2011 Sportsman 550 Touring EPS -- Wifie
Sold 2009 Sportsman XP 850 Sold
Purchase date: May 2009
Sold date: December 2010
biz4two is offline
post #6 of 7 (permalink) Old 05-23-2019, 01:21 PM Thread Starter
Tiderencel's Avatar
biz
So I tried soaking it but not like completely covered just in whatever left over spray. Took it all apart sprayed and blow air and tried a torch tip cleaner the the jets. Then last time rebuilt with new jet, needles, and gaskets. Ran good but then the problems I said before. I did just check the valves and new plug and cleaned tank and fresh gas (did have small flakes in gas) still no improvement. Checked compression with a weird gauge only got 80psi but I want to get a different gauge since I don't trust that one. I can get it to start better if I pull the brand new air filter off but still can't run on it's own. Thinking still the jet? I was going to try cleaning it again and soaking it, any product you suggest or way of doing it? This would be my 5th 6th time so any thoughts would be great. Thanks again.
post #7 of 7 (permalink) Old 06-08-2019, 05:16 PM
biz4two's Avatar
Arrow
Sounds like you have issue with the air circuit of the carb or the vacuum hoses on the airbox side. If adding the air filter causes the engine to stall, then you are not getting the necessary air and fuel blend needed to run.
Check those air vent lines...and replace if necessary. Sounds like you did a good job cleaning the carb, so thinking you might be good on that end.
biz
biz4two is offline
Oil in Air Filter box // !! rusherjim Polaris Sportsman 5 03-16-2019 02:14 PM
2003 Polaris Magnum 330 want run good with air box cover on Blue Ridge ATV Repair and Maintenance 6 03-04-2019 05:28 AM
Polaris Outlaw 50cc - Air Shocks - 100% Improvement over Stock willyg1997 ATV General Discussion 1 01-09-2019 12:07 PM
2009 Sportsman 400 HO air box ??? adamrich33 Polaris Sportsman 10 06-28-2018 03:04 PM
My Polaris Lock & Ride XL Box review (lots of pics) SportsmanMX ATV Visual & Body Modifications 2 04-16-2016 09:10 AM
