polaris runs rough 1/4 throttle - Polaris ATV Forum
Polaris Phoenix Discussions relating to the Polaris Phoenix
post #1 of 10 (permalink) Old 02-26-2018, 04:04 AM Thread Starter
edfl's Avatar
Hey guys new member my sons polaris had been sitting several years because bolts back out of stator and chewed up stator and flywheel just got one from ebay used installed it runs perfect but at 1/4 only when hot breaks down. It seems like spark but only after about 1/2 hour of driving new plugs carb is clean any ideas would be great thanks again
edfl is offline
post #2 of 10 (permalink) Old 02-26-2018, 04:11 AM
Rico1's Avatar
What machine is it?
Rico1 is offline
post #3 of 10 (permalink) Old 02-26-2018, 05:26 AM Thread Starter
edfl's Avatar
2007 sawtooth 200cc
2007 sawtooth 200 cc
edfl is offline
post #4 of 10 (permalink) Old 02-26-2018, 05:39 AM
Check the air box for a mouse nest and/or clean the carb - you said it sat for 2 years, but you didn't say if the carb and fuel tank were drained before it sat
latebird is offline
post #5 of 10 (permalink) Old 02-26-2018, 06:13 AM
Rico1's Avatar
Good call Latebird. If no nest I would double check the pilot jet as well. The bolts backing out on those machines must have been a common issue, I have repaired two of them with the same problem. Did you loctite the bolts?
Rico1 is offline
post #6 of 10 (permalink) Old 02-26-2018, 06:26 AM Thread Starter
edfl's Avatar
yes lock tite bolts the old gas was drained but not carb crazy is it runs and idles perfectly it only happens on the throttle exactly at 1/4 and only hot its like a safety is acting up breaks down like electrical or spark has tons of power till about a good half hour of driving dont bog at all just jerks
edfl is offline
post #7 of 10 (permalink) Old 02-26-2018, 06:37 AM
Rico1's Avatar
Sorry, didn't pick up on the half hour part. Definitely sounds electrical in nature, could be a bad coil or spark plug cap(assuming it is a resistor cap), might also be the voltage regulator but i would think that would be problematic all the time, best I can offer, there are lots on here with far more knowledge of electrical systems than me, hopefully someone can help you resolve the issue.
Good luck.
Rico1 is offline
post #8 of 10 (permalink) Old 02-26-2018, 06:56 AM Thread Starter
edfl's Avatar
thanks, i can try a coil next I guess but much-appreciated hate to drop it off at a shop when it takes so long to get hot before it happens
edfl is offline
post #9 of 10 (permalink) Old 02-26-2018, 12:13 PM
Sweet_Tooth's Avatar
Send a message via Yahoo to Sweet_Tooth
Check carb and clean jets. Phoenix 200s are notorious for clogging if you let them sit for a month so even two years might clog them as well.
My Polaris Fleet:
2015 Polaris Ranger 900 XP Sandstone Metallic.
2012 Polaris RZR S 800 Liquid Silver LE (Wife's Ride)
ATVs
2018 Polaris Sportsman 450 & 570 (Sage Green)
2018 Can-Am Outlander 570 x2 (Red non-EPS and Orange EPS)
Sweet_Tooth is offline
post #10 of 10 (permalink) Old 06-08-2019, 10:43 AM
Cdubbs's Avatar
'08 Polaris Phoenix 200
I keep seeing similar posts about this issue with no solutions. I too have the same issue going on with my sons phoenix. it ran great all through the throttle range then one day it died. Battery was almost to hot to touch and cdi split open. I replaced battery, cdi, coil, plug and wire and after this it started right up and I thought I had fixed it. However, it then would start and idle just fine but would act like its starving itself of either fuel or air and "stumble" when given any throttle. I then proceeded to replace the voltage regulator, pulled and cleaned the carb, tried different jet settings, drained the fuel tank, replaced the fuel filter and blew out the fuel and drain lines, cleaned the air filter, checked grounds, put dielectric grease in plugs, swore at it and still it persist on running the same. Anyone have any other ideas?
Cdubbs is offline
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix
02 500 6x6 thumb throttle NYrancher ATV Repair and Maintenance 2 01-30-2018 07:05 AM
92 polaris 250 throttle gos up in reverse all buy it's self kooken Polaris Trail Boss 3 06-05-2017 05:34 PM
polaris 570 2015 exhaut heating gab570 Polaris Sportsman 2 05-19-2017 10:58 AM
Polaris Sportsman 500 6x6 running rough when warmed up cruiser83 ATV Repair and Maintenance 10 04-12-2016 07:55 AM
Welcome to the new Polaris ATV Forum! dascrow Polaris ATV News 2 09-20-2010 01:39 PM
