New Battery Keeps Going Dead - Polaris ATV Forum
post #1 of 15 (permalink) Old 08-19-2017, 09:22 AM Thread Starter
gobigparts's Avatar
I just put a new battery in my predator 500 and it is already dead after a week. What am I doing wrong. I bought the quad last year and didn't seem to have this problem last year. Does the key and the Run switch both have to be off. Because I have been just turning the key off. Is there a lead off the magneto and relay or something that charges the quad when it running?
gobigparts is offline
post #2 of 15 (permalink) Old 08-20-2017, 05:12 AM Thread Starter
gobigparts's Avatar
voltage regulator maybe?
post #3 of 15 (permalink) Old 08-20-2017, 05:21 AM
bp405's Avatar
Chk the DC voltage at the bat terminal with the machine running @3,000 rpm.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #4 of 15 (permalink) Old 08-20-2017, 05:21 AM
bp405's Avatar
*******First charge the battery fully.********
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #5 of 15 (permalink) Old 08-20-2017, 05:37 AM Thread Starter
gobigparts's Avatar
Did that twice now. I purchased a maintenance free battery which I had to add the acid myself and fully charge.
post #6 of 15 (permalink) Old 08-20-2017, 05:42 AM
bp405's Avatar
Well if it's "did" and I'm assuming you meant dead then it needs to be charged fully before you test the charging system.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #7 of 15 (permalink) Old 08-20-2017, 06:05 AM Thread Starter
gobigparts's Avatar
OK, I charged it over night so it should be good to test.
post #8 of 15 (permalink) Old 08-20-2017, 06:16 AM
bp405's Avatar
Good so post up what it's putting out. Should be in the 13.5-14.5VDC range.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #9 of 15 (permalink) Old 08-20-2017, 01:39 PM Thread Starter
gobigparts's Avatar
I'm up North with no meter. Will have to do it next time we come up.
Sent from my Pixel XL using Tapatalk
post #10 of 15 (permalink) Old 09-12-2017, 12:26 PM Thread Starter
gobigparts's Avatar
Thumbs up
Well a meter would have gone a long way. Found out my new battery is bad. Will not charge all the way. I sent it back an ordered a better quality maintenance free battery by YUASA and followed directions for filling and charging. Took it off charger today and had Just over 13 volts on the battery with my meter. Installed it in quad and fired it up. I had just over 15 volts with it running. I believe I am good to go.
Thanks for the help everyone.
New battery, battery dead. 2015Sportsman Polaris Scrambler XP 5 11-18-2018 03:16 PM
2012 550 X2 battery upgrade Stormrider1961 ATV Repair and Maintenance 1 01-16-2017 11:31 AM
2016 Battery Dead Slready WTF Streetglide515 ATV General Discussion 13 12-31-2016 02:41 AM
Handy battery terminal access bullseyeguy ATV Performance Modifications 15 12-19-2016 04:49 AM
Ran without battery: Dead now. Jeff405 ATV Repair and Maintenance 5 09-14-2016 05:26 AM
