Blown Motor - Polaris ATV Forum
Polaris Scrambler XP Discussions for the all new 2013 Polaris Scrambler XP 850
 5Likes
post #1 of 11 (permalink) Old 05-23-2019, 03:02 AM Thread Starter
JohnJr's Avatar
Blown Motor
2013 850, bought it brand new in April 2013. Followed maintenance to the letter, serviced every 100 hours, (about a year and a half). K&N air filter, Polaris extreme duty oil change kits. Basically stock, with a few body mods (armor, fender flares..).
Having trouble with it starting, thought it was the throttle positioning sensor (tps). Send it in for the change (has the original tps) and after a good look over they find that the compression in both cylinders is around 100psi when it was supposed to be 200psi. 5500 miles on it. They think it’s the rings and will know more once they start tearing it down.
I’m a northeast rider, not a big water or mud fan but have done it. Lots of dust up here.
Looking for thoughts on what happened and how to avoid another 2000.00 bill in the future!
JohnJr is offline
post #2 of 11 (permalink) Old 05-23-2019, 03:51 AM
indyred570's Avatar
Just my opinion, but I would look into another air filter & get rid of the K&N. Most would say to service it at least once a year too.
2014 Sportsman 570
Powermadd Hand Guards
Viper Elite 3000 Winch/KFI mount
Denali Snow Plow
Polaris HD Front Springs
Kenda Executioners
Ricochet A-arm guards
QSC clutch kit
indyred570 is offline
post #3 of 11 (permalink) Old 05-23-2019, 04:50 AM
Liftedpsd's Avatar
Before reading the last reply I can promise you the KN air filter is your problem. Check the air filter tube after the air filter for dust.
Liftedpsd is online now
post #4 of 11 (permalink) Old 05-23-2019, 06:53 AM
Browning850's Avatar
I second this, I got my 2010 from a guy that had a K&N in it when i bought it. Did lots of research and the first thing i did was buy a OEM Polaris filter.
Saw lots of People getting blow by with the K&N, Most in dust were using OEM or UNI, Most having the best luck with the UNI with dusty conditions.
Good Luck, and thanks to this forum and others for Great Info!!
2010 Sportsman XP 850 LE Browning Ed
Factory Heated Grips & Throttle
Pure Polaris Warn Winch 3000lbs
Warn Synthetic Rope
Polaris F&R Brush Guards
Lock & Ride Rear Cargo box
Lock & Ride Tall Windsheild
Rear view mirrors
Cecca Frame braces
Browning850 is offline
post #5 of 11 (permalink) Old 05-23-2019, 07:37 AM
Yes, K&N filters are bad for rings especially in dusty conditions. The filter need to be serviced properly about once a month depending on conditions. If you ride in a group and ride for a few hours every weekend, the filter should be serviced after each ride. If you use a pre-filter sock, the sock needs to be cleaned after each outing, but the filter may not need servicing for a month or so. If you intend to stay with K&N, it's best to have 2 filters; one in and one ready to go in. Proper servicing takes about a hour or two using the K&N filter service kit. K&N's flow more air, but unfortunately they flow more dust too. Those fine particles of dust can wear out rings in a relatively short time. Extreme example: I bored a cylinder, installed a new piston and rings into a Yamaha 100 for a kid who was racing motocross. He didn't have the money for a new air filter, so he taped about 4 layers of an old nylon stocking over the inlet bell of the carb. He raced two semis and a final the following Sunday. On Monday he was back at the shop and said after he finished the moto, the bike died and he couldn't restart it. It had no compression - I took it apart and it needed bored out again - the rings were paper thin on the intake side - I told him I would not fix it again if he did not put a good filter in it - I fixed it and it wasn't too long after that the crank went bad - it was never fixed after that.
Corbett1973 and FPD218 like this.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is online now
post #6 of 11 (permalink) Old 05-23-2019, 08:34 AM
Yep, K&N = its been dusted and the rings are gone.
polman500 is online now
post #7 of 11 (permalink) Old 05-23-2019, 05:11 PM Thread Starter
JohnJr's Avatar
I would clean the filters about twice a year, prefilter and filter, dry and reoil. Would take me an overnight so it would dry well before I oiled and reinstalled. I also use a little filter grease where it seats into the box. Very surprised by all the comments, does get me to thinking. I will have the shop check the line from the box to the intake.
JohnJr is offline
post #8 of 11 (permalink) Old 05-28-2019, 12:10 PM Thread Starter
JohnJr's Avatar
Update! Just spoke to the shop, problem was NOT contamination from poor filtered air. It was a spun timing gear! This is an older machine, they had pressed the timing gear on instead of welding them like they do now. Will have her back later this week!
Corbett1973 likes this.
JohnJr is offline
post #9 of 11 (permalink) Old 05-28-2019, 01:38 PM
So you are telling us the shop that diagnosed the 'blown engine' made an incorrect diagnosis? How far did they have to tear the engine down before they realized it had slipped time? Do they propose to re-time it and weld the gear in place without complete engine disassembly or are they going to replace the crankshaft?
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
post #10 of 11 (permalink) Old 06-11-2019, 03:54 AM Thread Starter
JohnJr's Avatar
The leak down test after the original compression only test started to indicate a different problem. When they took the head off they found valve impact marks on the pistons, first clear indication of the slipped timing gear. They had seen this once before. They did a complete tear down, checked the valves, reseated, replaced the pistons and welded the timing gear back on the crank after checking for chips and cracks. Basically freshened up the top end of the motor. Here is a pic of the crank. You can see the timing marks are misaligned.
Have it back and it feels much better, must have been at reduced power for a while, but slowly, so never noticed it. Big ride in Maine this week. Will see how she does.
Corbett1973 and Liftedpsd like this.
JohnJr is offline
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Scrambler XP
1987 Trailboss es/r 250CC starter shot Rufusjr Polaris Trail Boss 2 04-28-2019 01:53 PM
New motor won’t stay running Garret Olmsted ATV Repair and Maintenance 8 01-15-2019 06:25 AM
Any interest in a 2015 850SP with blown motor Duse ATVs For Sale 0 11-06-2018 01:30 AM
550 xp motor blown? Workmore ATV Repair and Maintenance 1 08-21-2018 02:56 PM
Five Best Motor Oil Options for ATVs and UTVs VS_Goose Polaris ATV News 2 06-24-2017 06:29 AM
