Timing Gear Slipped - Poor Engine Performance - Page 40 - Polaris ATV Forum
Polaris Scrambler XP Discussions for the all new 2013 Polaris Scrambler XP 850
 2Likes
post #391 of 412 (permalink) Old 11-10-2017, 08:13 PM
Old509cc's Avatar
Most people don't consider or understand the stress that a key puts on a shaft. If the gear was splined or properly bonded the result would have been even more reliable than a keyway.
I am however with the rest of the crew that this is an awful issue that was not handled well.
My ride
1999 Sportsman 509
Rebuilt. R2C air filter. BST40. QSC clutch kit in a QSC primary. Block & tank heaters.
Steel grease-able rod ends. HPD steering bushing. Custom hub vents.
Custom prop shaft lock collar. Rhino cv front axles. Borla 14" Pro XS muffler.
25" Sedona ripsaws on 12" Badlands. 2" level. Oury grips over hand-warmers.
Backup light. LED low beams. HID 35W high beam. Rev override switch delete.
Cooling fan light. Alba water temp, VDO volt, oil temp & pressure gauges.
Dad's
2014 Sportsman 570 EPS
2500 winch. Hand warmers. L&R windshield. L&R rear box. 60" Glacier. 26" HTRs.
Brothers'
2006 Sportsman 500 HO
2500 winch. 24" box. Prop shaft lock collar. LED low beams.
2014 RZR S 800
Superwinch Tera 3500. Roof, custom mounts. Pawltector parking brake.
F&R bumpers. Custom fire extinguisher mount. Rear diff pinion nut Torqued.
Faithful friends no longer with us
2004.5 Sportsman 500 HO.
2007 Rincon 680
Old509cc is offline
post #392 of 412 (permalink) Old 12-15-2017, 02:32 PM
flyinghigh's Avatar
So to boil this all down, after a bunch of time digging through parts diagrams and on the phone with my dealer, here is the deal.
All Machines 2010-2013 (according to the parts manuals) were made with crank 2204233 which was made with a pressed on timing gear until 2014 when they tried to remedy the problem with 2205283.
They ran crank 2205283 for MY14-15-16 until they finally fixed the old 2204233 and put in it MY 2017.
If you look at the parts for MY14-16 you will see the 2205283 now super ceded by the "new" 2204233. Very deceptive. They should have come up with a new PN for the MY17 cranks to SHOW they had a new crank based on the old 2204233...but then everyone would have been demanding a new crank. (as well they should) So the easy cover-up was to "fix" the old 2204233 and no one is the wiser.
Even the old 2009 which used crank 2203926 (never used again after that model year) now shows super ceded with the "new" 2204233.
So the bottom line is that if you are driving around with the original 2204233 you are at a risk to have it spin. If you have a 2014-2016 with crank 2205283 you should be ok, and if you have a 2017 with the new 2204233 you should be ok.
flyinghigh is offline
post #393 of 412 (permalink) Old 12-25-2017, 09:21 PM
camo850XP's Avatar
Originally Posted by flyinghigh View Post
So was this corrected on the 2014s?
there was one guy in the beginning of this thread that had a 14 with the pressed on gear.
2014 Polaris Sportsman XP 850 HO EPS Pursuit Camo
1999 Polaris Sportsman 500 Remington edition
2010 Polaris Sportsman XP 550 Touring EPS
camo850XP is offline
post #394 of 412 (permalink) Old 12-31-2017, 04:32 PM
camo850XP's Avatar
when did they start welding the 14s? i have a 14 with a build date of 11/07/2013
post #395 of 412 (permalink) Old 06-03-2019, 08:26 AM
Tintman20's Avatar
Sorry to bring back a dead thread. Just picked up a 13 850 xp. It has almost 5000 miles on it and the engine has never been touched. Should I still be concerned about the timing gear? I figure if it made it this far it should be fine. Input please.
Tintman20 is offline
post #396 of 412 (permalink) Old 06-03-2019, 05:23 PM
Jason537's Avatar
If you are that worried, pulled the rocker cover and look down at the crank. You should see 1 black mark in the crank and another mark on the gear,.. they should line up. I was lucky and caught mine before it went too far, my quad only has 800mi.
Do you have a low power, hard starting, or erratic idle issue?
Name:	timing gear slipped.jpg
Hers 2014 570 sportsman,
2" AtvE lift
His 2013 850xp LE, currently under REPAIR for spun timing gear
28" Zillas
1.5" lift
LTE slip-on,
Jason537 is offline
post #397 of 412 (permalink) Old 06-03-2019, 05:32 PM
Tintman20's Avatar
No it runs smooth starts easy and loads of power. It does have the occasional high idle but that’s a different issue I’d guess. I’m just wondering if the gear is still at danger of slipping at this point in its life.
post #398 of 412 (permalink) Old 06-03-2019, 06:34 PM
bobx2's Avatar
I would think it would be okay, but impossible to know. I think mine had 1,700 or 1,800 miles or so on it when mine slipped the first time. After the second time I was always nervous, and never fully trusted it again.
2018 Polaris General 1000, Elka Stage 2 Shocks, 29" Tusk Warthogs, Polaris 4,500 lb. winch, Factory UTV Skid Plates, Dux Turn Signal/Horn Kit, EMP Cooter Brown Roof, Ryfab Folding Glass Windshield, Spring Brake Thingy
2015 Sportsman 570 Touring EPS, 26" Kenda Bearclaw HTR's on ITP Delta Steel wheels, Warn Vantage 3000, Elka Stage 1 Shocks, Warn Mid-Mount Plow (Wife's)
bobx2 is offline
post #399 of 412 (permalink) Old 06-04-2019, 06:09 AM
Tintman20's Avatar
Does the top end have to come apart to split the cases? Or can I just pull the engine split the cases weld the gear and reassemble?
post #400 of 412 (permalink) Old 06-04-2019, 09:00 AM
HawkX66's Avatar
If you're asking that, I'd highly suggest you get some on-site help. Yes. Top end needs to come off to split the lower end case.
Semper Fi!
04 Sportsman 600 4x4
HawkX66 is offline
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Scrambler XP
has your belt slipped? grub Polaris ATV Polls 133 11-19-2015 10:13 AM
1991 Trail Boss 350 Exciter Coil and engine timing papamech ATV Repair and Maintenance 4 09-28-2012 11:46 AM
Cam gears slipped? JoeW Polaris Predator 14 06-24-2012 07:49 AM
Performance poor? brumey Site Issues & Suggestions 5 07-02-2010 05:06 AM
Submerged in water. Poor rpm/ engine run. Any ideeas? iSnowboard ATV Repair and Maintenance 9 07-15-2009 12:17 PM
