Timing Gear Slipped - Poor Engine Performance - Page 41 - Polaris ATV Forum
Polaris Scrambler XP Discussions for the all new 2013 Polaris Scrambler XP 850
 2Likes
post #401 of 413 (permalink) Old 06-04-2019, 09:33 AM
Tintman20's Avatar
Don’t worry I’m good. Just never touched one of these before.
Tintman20 is offline
post #402 of 413 (permalink) Old 06-04-2019, 03:14 PM
Tintman20's Avatar
And btw I think your wrong. After a little research I believe the cases can be separated with the head in place.
post #403 of 413 (permalink) Old 06-04-2019, 05:14 PM
Jason537's Avatar
You can remove the crankshaft without removing the head that's how I did it.
Hers 2014 570 sportsman,
2" AtvE lift
His 2013 850xp LE,
28" Zillas
1.5" lift
LTE slip-on,
Welded timing gear
Jason537 is offline
post #404 of 413 (permalink) Old 06-05-2019, 02:26 AM
Tintman20's Avatar
Thank you.
post #405 of 413 (permalink) Old 06-06-2019, 11:48 AM
Tintman20's Avatar
What position does the engine need to be in to view the marks via the timing chain opening? Number 1 TDC on compression stroke?
post #406 of 413 (permalink) Old 06-06-2019, 03:47 PM
Tintman20's Avatar
Aligned perfect after almost 5000 miles.
Anybody know the valve clearance specs for these? May as well check it seeing I’ve got it open.
post #407 of 413 (permalink) Old 06-06-2019, 05:08 PM
Jason537's Avatar
Zero lash
2" AtvE lift
His 2013 850xp LE,
28" Zillas
1.5" lift
LTE slip-on,
Welded timing gear
Jason537 is offline
post #408 of 413 (permalink) Old 06-06-2019, 05:46 PM
Tintman20's Avatar
Originally Posted by Jason537 View Post
Zero lash
Can you explain the procedure for these engines or a link to set it? The manuals I’ve found online say .006 for intake and .009 for exhaust but I didn’t think it was correct. I couldn’t even get the .006 in the exhaust side.
post #409 of 413 (permalink) Old 07-31-2019, 03:15 PM
Jason537's Avatar
Can anyone confirm balancer shaft timing? The service manual says 1 way but shows another with DOT alignment.
ID:	119325   Click image for larger version
2" AtvE lift
His 2013 850xp LE,
28" Zillas
1.5" lift
LTE slip-on,
Welded timing gear
Jason537 is offline
post #410 of 413 (permalink) Old 07-31-2019, 03:22 PM
shane-o's Avatar
Hope this helps
2015 xp 1000 black pearl,
-polaris front and rear bumpers
-polaris hand/thumb warmers
-polaris body guard
-gse slip on
-front diff fix
-cecco frame braces
-lock and ride front box.
-dobeck fuel controller
-big horn originals/mega mayhems depending on the ride
shane-o is offline
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Scrambler XP
has your belt slipped? grub Polaris ATV Polls 133 11-19-2015 10:13 AM
1991 Trail Boss 350 Exciter Coil and engine timing papamech ATV Repair and Maintenance 4 09-28-2012 11:46 AM
Cam gears slipped? JoeW Polaris Predator 14 06-24-2012 07:49 AM
Performance poor? brumey Site Issues & Suggestions 5 07-02-2010 05:06 AM
Submerged in water. Poor rpm/ engine run. Any ideeas? iSnowboard ATV Repair and Maintenance 9 07-15-2009 12:17 PM
