1997 scrambler 400 2 stroke counterbalance shaft - Polaris ATV Forum
post #1 of 7 (permalink) Old 09-18-2018, 12:55 PM Thread Starter
tc862011's Avatar
My water pump went in my scrambler. I took it apart and the shaft on the counter balancer that drives the water pump broke off of the gear face. I have read that there can be grooves made over time from the seal I guess but there was barely any grooves not more then a couple hairs off your head. I am curious on why it broke because all the bearings are really good and there was no obstruction, looks like it just broke off. I did bottom out kinda hard on a rock through the trails but I donít see how that would have anything to do with it. Anyone have any input
tc862011 is offline
post #2 of 7 (permalink) Old 09-19-2018, 05:36 AM
Design flaw?
latebird is online now
post #3 of 7 (permalink) Old 09-19-2018, 05:39 AM Thread Starter
tc862011's Avatar
Yea I have seen allot of post of this happening especially with a 20 year old machine. Thought about converting to an electric water pump but decided against it. Hope this is the only time it happens
tc862011 is offline
post #4 of 7 (permalink) Old 09-19-2018, 06:07 AM
How do you plan on fixing it? Although the counter balance shaft has been superseded from 3084172 to 3087042 and it's still available, it costs $580! I could get you one for about $400 as could a sympathetic dealer, but is it worth fixing?
post #5 of 7 (permalink) Old 09-19-2018, 06:09 AM Thread Starter
tc862011's Avatar
I just found one on eBay for $100 it has no grooves in it so it should be good to go. If it breaks again I will be figuring out how to make an electric pump work, found one for $150 just wasnít sure if it had enough liters per minute to match up to oem
tc862011 is offline
post #6 of 7 (permalink) Old 09-19-2018, 06:41 AM
It's not the grooves from the seal that caused the break - it was the failure to radius the transition from one diameter to another diameter of the shaft. Inspect the replacement shaft carefully and maybe take it to a machine shop for modification before installation. A good machinist should be able to look at the breakage and suggest a modification that will prevent future breakage.
post #7 of 7 (permalink) Old 09-19-2018, 07:04 AM Thread Starter
tc862011's Avatar
Thank you that helps very much, wouldnít of thought of that
tc862011 is offline
96 sportsman bjok Polaris Sportsman 1 02-18-2018 06:59 AM
Scrambler 400 4 stroke options bryanwheat ATV Performance Modifications 0 03-09-2017 08:52 PM
Opinions on Polaris Scrambler 400 2 stroke 4x4 CumminsAddict16 ATV General Discussion 14 03-10-2016 08:23 AM
