2000 Polaris scrambler 500 throttle dies - Polaris ATV Forum
post #1 of 3 (permalink) Old 11-01-2018, 11:12 PM Thread Starter
Hardyfoods's Avatar
Hello,
First off thanks for any feedback you might have with my issue.
I just picked up a 2000 scrambler 4x4 cheap, it had been sitting for 3 years and previous owner stated it had an issue with "throttle". I'm not too mechanically inclined but I had a friend who is check it out and I bought it.
Changed the battery, pulled the carb as it would start but wouldn't continue running and die. Ordered another throttle cable and changed that out, changed the spark plug, cleaned the carb and put it back in (mixed up the hoses and flooded the carb, waited until it drained) and it fired up and idled with starter fluid. It idled great but any time we used the throttle it would sputter and die.
We emptied the gas and changed it to ethanol free (clean) gas.
I took the carb out again to take a closer look and noticed the choke handle had broken off (closed) also when pulling the fuel line it is definitely getting fuel as fuel came out..
I've looked online and have heard these machines have issues with the cam shaft I guess that's the next move, does anyone else have any input as to what else could be the problem?
Thanks in advance!
Hardyfoods is offline
post #2 of 3 (permalink) Old 11-02-2018, 12:53 AM
autosport7's Avatar
Check compression, If that checks out Id buy a new carb.
$40 and has good reviews:
https://www.ebay.com/itm/NEW-CARBURE...YAAOSws6ZaQWNc
2015 Polaris Scrambler XP1000
Red Bull Graphics Kit
Spider Graphix - Footwell Dacals
Mud Motorsports Gripper Seat Cover
Rogue Grille - Blk/Blk/Red
Pure Polaris Hand Warmers
Pure Polaris Thumb Warmer
GBC Grim Reaper - 26/9/14 - 26/11/14 on Hiper Sidewinder Beadlocks
All Balls Wheel Bearings FR/RR
ROX Speed FX Foot Pegs
CECCO Frame Braces FR/RR
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Moog SSB Upgrade W/ Custom Zerk
Powermadd Sentinel Handguards
Renthal G169 Grips
Gear
Leatt 5.5 V.05 Turbine - Helmet
Oakley Airbrake - Goggles
EVS Sport - Chest/Back Protector
OGIO Dakar - 3L Hydration Pack
Shift Recon - Pants/Jersey/Gloves
Alpinestars MXGP - Jersey
Alpinestars S-MX Air Carbon Mesh - Gloves
Alpinestars Tech 8 - Boots
autosport7 is offline
post #3 of 3 (permalink) Old 11-02-2018, 05:33 AM
I'd just clean and repair the original carb - when you open the throttle you are giving the engine air - NOT GAS - it's the job of the carb to mix the right amount of fuel with the air to get a combustible mixture. The carb is not mixing enough fuel with the air to keep the engine running. Just repair the carb - a thorough cleaning and re-calibration is probably all that's needed (along with repairing the enrichener)
latebird is online now
Sportsman 600 Primary Help Needed TooSlo ATV Repair and Maintenance 8 07-23-2018 11:58 AM
2005 Polaris Sportsman 500 H.O Throttle Lever Mike97 Polaris Sportsman 1 12-07-2017 12:26 PM
2000 Polaris scrambler 90 Deermeat93 Polaris Scrambler 1 09-18-2017 10:28 PM
Hub strut compatability sniper4x4 ATV Brakes & Suspension 3 04-05-2016 07:24 AM
