Polaris Scrambler 4WD repair - Polaris ATV Forum
post #1 of 4 (permalink) Old 06-11-2019, 05:09 AM Thread Starter
sarahhw's Avatar
Good morning! The 4WD on my 1999 Scrambler 400 hasn't worked since I got it and I can't seem to figure out why. I've torn apart the hubs and everything seems to be in working order. Is there a way for me to check the electrical? I found a thread that went through it but what he described doesn't match up with my ATV. I also found a wiring diagram that I thought was correct but it's different too. Any help would be appreciated.
sarahhw is offline
post #2 of 4 (permalink) Old 06-11-2019, 05:59 AM
Get all 4 wheels off the ground - start the engine, engage the AWD, set the brake, shift into forward gear, let off the brake and give it some throttle - if all 4 wheels turn it's working!
If the front wheels do not turn as the engine accelerates, find where the hub wires plug into the wiring harness, connect 12 VDC to the wires going to the hubs and try again - if the wheels turn, troubleshoot the AWD circuit - if the wheels do not turn, take the hubs apart and trouble shoot the Hilliard clutch drive components.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #3 of 4 (permalink) Old 06-11-2019, 06:53 AM Thread Starter
sarahhw's Avatar
I've jacked it up and know for sure that it isn't working. I'll try the 12 VDC when I get home tonight. How would I go about troubleshooting the AWD circuit? Also, there are four wires that come out of the AWD button/switch on the left handlebar and they're wrapped and when I traced them only three came out the other end. I unwrapped them and two of them are spliced together but it looks more like a factory splice. Is it supposed to be like that? Or are there supposed to be four wires connecting on both sides?
sarahhw is offline
post #4 of 4 (permalink) Old 06-11-2019, 09:04 AM
I'm not familiar with the AWD button being on the left - every thing I has says it's on the right in the throttle housing.
I'm going to presume you have an early model as you say there is only 4 wires coming out of the throttle housing. Late model had 6.
Gray wire went to the hub coils, gray/white went to the gear selector forward wire and the black is the throttle safety switch.
If you have 12 volts on the gray wire, you either have a grounding issue or possibly a faulty hub safety module LR-83-1.
If there is not 12 volts on the gray wire, press the override switch and see if 12 volts appears.
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
latebird is offline
