2016 Polaris Sportsman 570 Overheat Problem - Polaris ATV Forum
 1Likes
post #1 of 11 (permalink) Old 09-11-2016, 08:23 AM Thread Starter
Beretta's Avatar
I recently bought this bike 2 months ago, and have fell in love with it. I've already replaced the front right axle on it (my own fault for where I was going), but otherwise have had no problems with it.
Recently, after riding for about 2-3 minutes the Over Temperature light will come on, the bike will go into its "Engine Saving Mode", and then the light will start flashing and die. When I feel the sides of the motor, it is not very hot at all and should not be enough to be causing it to shut off. I checked fuses and relays along with the radiator to see if it was clogged, and the fluids are all in check as well. I don't really know what else to check, and any help would be greatly appreciated.
Beretta is offline
post #2 of 11 (permalink) Old 09-11-2016, 08:46 AM
SteveC25's Avatar
Is the radiator fan coming on?
SteveC25 is offline
post #3 of 11 (permalink) Old 09-11-2016, 08:50 AM Thread Starter
Beretta's Avatar
Yes, and will stay on as long as you have the key on. I let it run for 3 minutes after the bike died, and never shut off on its own.
But after I turned the key off and let it sit for 10 minutes, I could run the fourwheeler for another 2-3 minutes before it would do the same thing again.
Beretta is offline
post #4 of 11 (permalink) Old 09-11-2016, 04:07 PM
sporty061200r's Avatar
Is there any antifreeze in it
sporty061200r is offline
post #5 of 11 (permalink) Old 09-11-2016, 08:56 PM Thread Starter
Beretta's Avatar
Yep topped it off just to make sure.
Beretta is offline
post #6 of 11 (permalink) Old 09-12-2016, 06:55 AM
Tinybear's Avatar
I don't know these engines at all really but all that comes to mind for that issue generally would be
1. A temp sensor fault
2. Thermostat stuck closed
3. Failed water pump
2017 Suzuki V-Strom 650 XTSE
2010 Yamaha TW200
2005 Suzuki Ozark 250
2016 Sportsman 450HO
Tinybear is offline
post #7 of 11 (permalink) Old 09-12-2016, 09:14 AM
ThorsHammer's Avatar
you may have air in the anti freeze causing improper reading in the temp. Raise the front of the machine 12+" and burp the coolant to make sure that all the air is out of the system.
iowasteve72 likes this.
2017 Sportsman 570 Touring EPS
3500 lbs Polaris winch with Synthetic Rope
Front Utility Rack
ODI Rogue Lockon Grips
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
ThorsHammer is offline
post #8 of 11 (permalink) Old 09-12-2016, 09:20 AM
darius427's Avatar
Radiator is not caked with mud/dirt is it? I have seen this cause overheat issues before.
My up north ride
2016 Sportsman 570SP (Titanium Matte Metallic)
My at home ride
2013 Sportsman 800 (Green)
Wifes
2015 Sportsman 570SP (Sunset Red)
2013 Sportsman 500 (White)SOLD
darius427 is offline
post #9 of 11 (permalink) Old 09-12-2016, 09:38 AM Thread Starter
Beretta's Avatar
I did this and have run it up and down the road multiple times without it saying its overheated. Seems to have fixed it, thank you.
Beretta is offline
post #10 of 11 (permalink) Old 09-13-2016, 09:50 AM
Seems to be a pretty common issue lately.
Front Utility Rack
4" LED on the pod
  • Dynojet kit
Tags
570, overheating
Reverses without throttle (2016 POLARIS Sportsman 570 Touring SP EPS) maverickmar Polaris Sportsman 570 19 09-06-2016 02:52 PM
2016 Polaris Sportsman 570 question Smoore46 ATV New Members 5 06-24-2016 05:15 PM
2016 Polaris Sportsman 570 question Smoore46 ATV General Discussion 2 06-18-2016 01:14 PM
May 2016 - Polaris ATV of the Month Voting! Wreckless ATV of the Month 1 05-16-2016 07:02 PM
