2017 How to get engine code ? - Polaris ATV Forum
post #1 of 7 (permalink) Old 08-27-2018, 03:36 AM Thread Starter
191285's Avatar
2017 Sportsman 570
Check engine light came on for a few seconds, then went away .
The display said "chk eng" or something to that matter..
How do I get the code ?
191285 is offline
post #2 of 7 (permalink) Old 08-27-2018, 04:44 AM
mvn
mvn's Avatar
In order to retrieve codes, the Check Engine light must be on. If it's off, there's no way of retrieving historical codes via the display. Only way I believe is to have a dealer hook up their scan tool.
Mark
2012 850HO Touring EPS Pearl White
27" ITP XTR radials on 14" ITP SS212 wheels
Ricochet skid plates & A-arm guards
Rubberdown 1 1/2" lift
Cecco frame braces
JC Capri bushings
Rotopax fuel packs on custom mounts
Garmin 60CSx with Ram mount
Polaris 2500# winch with synthetic rope
Polaris front & rear brush guards
Polaris bar & thumb heaters
Polaris passenger grip heaters
NGK (6043) ILZKAR7A10 plugs
Good, fast, cheap.....pick 2!
mvn is online now
post #3 of 7 (permalink) Old 08-27-2018, 04:54 AM Thread Starter
191285's Avatar
Ok, can you tell me how to do that? So if it stays on, i know how to get the code ?
191285 is offline
post #4 of 7 (permalink) Old 08-27-2018, 04:54 AM Thread Starter
191285's Avatar
So, if check engine light goes off, but the display still says check engine, i can not pull code ??????
191285 is offline
post #5 of 7 (permalink) Old 08-27-2018, 08:16 AM
mvn
mvn's Avatar
If the CEL indicator light turns on then goes off during one ignition cycle but the ignition key IS NOT turned off and Ck ENG is displayed, you can retrieve the code. See below.
Mark
Cecco frame braces
JC Capri bushings
mvn is online now
post #6 of 7 (permalink) Old 08-28-2018, 11:41 AM Thread Starter
191285's Avatar
Ok , where can I find the list of codes saying what they are ?
So that once I get the code, I can actually see what it means ?
191285 is offline
post #7 of 7 (permalink) Old 08-29-2018, 06:06 AM
mvn
mvn's Avatar
They are in your owners manual. You can download your manual if you don't have one.
Here.............
http://www.polaris.com/en-ca/atv-ran.../owners-manual
Mark
Cecco frame braces
JC Capri bushings
mvn is online now
2017 Sportsman 850SP phantom check engine light? SquireSCA Polaris Sportsman 10 02-09-2019 12:53 PM
2011 Polaris Sportsman 800 EFI ENGINE HArdwater08 Polaris Sportsman 1 09-14-2017 10:13 AM
white goo on engine oil stick and check engine code. bbehrendt Polaris Sportsman 570 13 03-13-2017 05:06 PM
