2016 570X2 Transmission seems to not be engaging - Polaris ATV Forum
 1Likes
  • 1 Post By bp405
post #1 of 4 (permalink) Old 02-14-2019, 02:20 PM Thread Starter
Nightattheroxbury80's Avatar
I have a 570X2 with 350 Miles. Was out riding in the snow the other day and all of a sudden there is no power. RPM's go up but no power to wheels, then its back to normal and now back to no power. I am from minnesota thought something froze up so had it in heated garage and still same issue. Any thoughts ?
Nightattheroxbury80 is offline
post #2 of 4 (permalink) Old 02-14-2019, 02:23 PM
bp405's Avatar
Check the belt housing for water.
2011 SportsmanŽ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 SportsmanŽ 570-T
2019 AlumaŽ A8818
2020 OutlanderŽ 1000R XXC (on order, ETA mid-Sept)
bp405 is offline
post #3 of 4 (permalink) Old 02-14-2019, 02:26 PM Thread Starter
@bp405 Wouldn't it be dry as I had it in a heated garage at 80 degrees for 24 hours ? I am not very mechanically inclined. Any help is appreciated
post #4 of 4 (permalink) Old 02-14-2019, 02:57 PM
bp405's Avatar
Not necessarily. Pull the red plug on the outside bottom of the clutch housing. If there is no water present I would suspect a glazed or broken belt. To verify that you would need to pull the clutch cover.
iowasteve72 likes this.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 AlumaŽ A8818
bp405 is offline
Any Polaris deep parts connections? TDMax Polaris Sportsman XP 1000 10 02-09-2019 09:13 AM
Ignition switch 570 sportsman Fivespeed ATV New Members 4 12-15-2017 07:03 AM
Transmission engaging Prematurely - sometimes keithh2oskier ATV Repair and Maintenance 19 02-20-2017 08:25 AM
