570 runs bad after washing - Polaris ATV Forum
 3Likes
  • 1 Post By bp405
  • 1 Post By bp405
  • 1 Post By jo191145
post #1 of 6 (permalink) Old 03-29-2019, 05:08 PM Thread Starter
justcallmejoe's Avatar
Not every time but maybe 1 out of 5 times after washing my 570 the wheeler starts acting up. It’ll start and idle but when I give it gas it bogs down. Let it sit overnight and everything is fine. Pretty obvious I’m getting water in a place where water shouldn’t be. Any ideas? It worries me that I’m going to get stranded one of these days after hitting some heavy water or mud areas.
justcallmejoe is offline
post #2 of 6 (permalink) Old 03-29-2019, 05:16 PM
bp405's Avatar
Yes!!!! I'd look the harness over for spots where the wires rubbed through. While doing that die-electric grease the connectors.
justcallmejoe likes this.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #3 of 6 (permalink) Old 03-30-2019, 02:17 AM Thread Starter
I'll go through it today and have a look. Honestly I'm not 100% sure what the heck I'm looking at though. As far as mechanics go I'm probably the last person you would want to look over your machine LOL. I'm good enough to change the fluids and grease the wheeler...maybe do a small mod here and there after that I'm pretty worthless.
I hate to do it but I may take it in and have it looked at.
post #4 of 6 (permalink) Old 03-30-2019, 06:31 AM
bp405's Avatar
It can be a bit overwhelming!!! Just try and pull as many plastics off as you feel comfortable doing. Then just look at the wire harness and wherever it looks like there could be a pinch point, sharp angle, or a spot where the wire harness is rubbing something. Then look at the harness in those areas and it'll be evident if there is damage. The loom and/or insulation will be worn. As you do this put something like a finger tip amount of die-electric grease on every connector you can get to.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #5 of 6 (permalink) Old 03-30-2019, 09:17 AM Thread Starter
Thanks for the info. I'll be digging into this tomorrow.
post #6 of 6 (permalink) Old 04-03-2019, 08:37 PM
jo191145's Avatar
Check your air box too. The drain plug on my 2018 is such a loose fit water gets into the box at high speeds. Idles fine but bogs when accelerating. Sucks water from the bottom of the box into the filter when accelerating hard. I just learned to hit the water slower. Fix it someday.
Muddy water was easy to see coming up through the drain. Clean water will be harder to see. If your hitting that plug with hose pressure it’s possible. Doesn’t take much water in the air box to mess it up.
jo191145 is offline
Any Polaris deep parts connections? TDMax Polaris Sportsman XP 1000 10 02-09-2019 09:13 AM
Polaris Ground Cable Lenght Hondov65 ATV General Discussion 3 02-06-2019 08:46 AM
Ignition switch 570 sportsman Fivespeed ATV New Members 4 12-15-2017 07:03 AM
