Alternate Method to Seal Clutch Case - Polaris ATV Forum
 5Likes
post #1 of 11 (permalink) Old 04-28-2019, 05:26 PM Thread Starter
rockhound's Avatar
After having the same water in the clutch case problem as others, I used a different way to seal the cover. I didn't care for the
grease and silicone way so I used an RV tape used to seal roof leaks. It sticks to just about anything and can be scraped off to remove. It is the number one RV sealing tape so I figured I'd give it a try. I used it in between the cover screws since the gasket is crushed between the screws but open gaps between them. And after many good size puddles and water holes I opened the drain screw and bone dry! Eternabond Tape, thought I would pass this along.
ID:	117555   Click image for larger version
ID:	117557   Click image for larger version
98whitelightnin likes this.
'16 Grizzly 700 EPS Mine
'16 Sportsman 570 SP EPS Hers
rockhound is offline
post #2 of 11 (permalink) Old 04-29-2019, 03:53 AM
indyred570's Avatar
Outsiders Motor Company has a seal kit for the Sportsman 570. Haven't purchased the kit yet, but I think I eventually will, no problems with my clutch cover leaking yet.
https://www.outsidersmotorcompany.com/
2014 Sportsman 570
Powermadd Hand Guards
Viper Elite 3000 Winch/KFI mount
Denali Snow Plow
Polaris HD Front Springs
Kenda Executioners
Ricochet A-arm guards
QSC clutch kit
indyred570 is offline
post #3 of 11 (permalink) Old 04-29-2019, 05:25 AM
I just maintain the factory foam seal and have never had a problem
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is online now
post #4 of 11 (permalink) Old 04-29-2019, 12:00 PM
98whitelightnin's Avatar
In regards to the link indyred570 posted, are people having problems with the airbox sucking dirt with the factory gasket? Although its new, I have thoroughly checked mine and it seems to make an airtight seal.
98whitelightnin is offline
post #5 of 11 (permalink) Old 04-29-2019, 03:11 PM
oilcan1001's Avatar
I have used that eternal bond on my RV and the name says it all !! That stuff is not going to be fun to try and get off when you need to
oilcan1001 is offline
post #6 of 11 (permalink) Old 04-29-2019, 04:39 PM
indyred570's Avatar
No problems here, just posted the link as an option to a better gasket if the oem looked bad or leaked.
2014 Sportsman 570
Denali Snow Plow
Kenda Executioners
QSC clutch kit
post #7 of 11 (permalink) Old 04-29-2019, 05:15 PM
From what I've seen, most leaks, especially on the newer machines, are from behind the INNER cover. I've never had any leaks through the outer cover so long as you have a good seal and you put the cover on straight and alternate tightening the screws. They also don't need to be too tight. Just good and snug. I go through some pretty deep river crossings to get into the back country and have never had a wet belt.
polman500 is offline
post #8 of 11 (permalink) Old 04-30-2019, 03:12 AM
jjuelmen's Avatar
Hey rockhound thatís a good idea! Iíve been using a peelable rtv used in service applications and thatís worked well too. Always like to see other ideas that work well.
Like most have said here already, a lot of leaks are at the back cover.
2015 Sportsman 1000 Titanium Matte LE
Polaris Body Armor
Polaris Front and Rear Bumpers
Triangle Stealth Snorkel
Powermadd Full Wrap Hand guards
Cecco Frame Braces
Cecco Billet Throttle
RC2 Filter
RJWC Baffle Tech Single Exhaust
Dobeck Programmer
LED Light Bar
RotoPax Fuel Cans
Outkast 3" arched arm lift
2009 Sportsman 550 XP EPS
2003 Scrambler 500 HO (Sold)
2007 Sportsman 800 EFI (sold)
jjuelmen is offline
post #9 of 11 (permalink) Old 05-01-2019, 11:26 AM Thread Starter
rockhound's Avatar
I had already taken the back cover off and did silicone the ring and new zip tie, just wanted to share the front cover as an alternative to grease and silicone. But hey, whatever works for everyone else is good too!
indyred570 and jjuelmen like this.
post #10 of 11 (permalink) Old 05-01-2019, 12:02 PM
What I'm saying rock, is that I've never seen any reason to add anything to the outer cover. As long as you have a good seal installed it won't leak under normal conditions. I suppose if you stay submerged a lot you might need something extra. I have had to spend an hour or two of shop time trying to get the RTV OFF some machines to access the clutches because the owner THOUGHT they were waterproofing it. It was an expensive lesson for them to have to pay me a couple hours labor for what should have been a 1o minute job just to get the cover off. Not to mention that once you go down that road it will NEVER seal properly again unless you spend a lot of time scraping and pealing the crap off there.
sportsmandan likes this.
Clutch question for the experts oilcan1001 ATV Repair and Maintenance 11 04-27-2019 05:32 PM
Sportsman 600 Primary Help Needed TooSlo ATV Repair and Maintenance 8 07-23-2018 11:58 AM
Sportsman 500 clutches Pluto75 ATV Repair and Maintenance 3 06-21-2018 06:26 AM
1994 Polaris 400L clutch cover alternatives? bigcheese ATV Repair and Maintenance 2 03-09-2016 12:19 PM
