2016 sportsman check engine light - Polaris ATV Forum
 3Likes
  • 1 Post By latebird
  • 1 Post By polman500
post #1 of 9 (permalink) Old 07-02-2019, 01:33 PM Thread Starter
justcallmejoe's Avatar
SPN code = 168
FMI code = 3
Runs rough at 1st start. Idles not so great. When I run it around the yard it seems to rev fine but if I let off the throttle and coast to a stop it dies. Anyone have any ideas? Does anyone know what that error code means?
The manual says this --- Voltage Above Normal, Or Shorted To High Source 168 3
justcallmejoe is offline
post #2 of 9 (permalink) Old 07-02-2019, 01:54 PM Thread Starter
I just checked voltage on my battery. ATV off = 13.23v, idle at 3000 RMPs = 18.52v
I have had the wheeler act like this before after riding in lots of water or after a washing. I'm stumped.
post #3 of 9 (permalink) Old 07-02-2019, 02:06 PM
Probably a bad rec/reg, a loose terminal on the battery or a shorted stator - check the terminal tightness - if OK, make sure the battery has a full charge - unplug the rec/reg and check the continuity of the stator - if the stator has continuity leg to leg and is not shorted to ground, leave the stator unplugged from the rec/reg and run the machine with the lights off for about 15 minutes - if it runs fine with the rec/reg unplugged, get a new one (rec/reg that is - not a new quad) - if the stator has no continuity leg to leg on any one leg or is shorted to ground, get a new stator - either way good or bad stator, it should run right with the stator unplugged from the rec/reg as long as the battery has an adequate charge.
justcallmejoe likes this.
latebird is offline
post #4 of 9 (permalink) Old 07-02-2019, 02:21 PM Thread Starter
Thanks. I'm hoping for a cheap solution here and with the way it's acted in the past after getting wet i'd bet it's a loose terminal or connection. I'll dig into this more tomorrow.
Thanks for the reply!
post #5 of 9 (permalink) Old 07-02-2019, 04:02 PM
Sounds like the VR to me. Do the testing latebird described and that will tell you where the problem is in a short few minutes. If its been doing this for a while in association with water exposure then you need to check/clean all connections and use dielectric grease while you're doing the other testing. It may be that intermittent water intrusion has now killed the VR.
Good luck and let us know what you find.
polman500 is online now
post #6 of 9 (permalink) Old 07-02-2019, 04:03 PM
Oh yeah, you can get a new VR on ebay for $45
post #7 of 9 (permalink) Old 07-03-2019, 05:30 AM
bp405's Avatar
Ditto on the VR!!!! I've used RMStator and Rick's Motorsports Electric for my aftermarket non OEM electrical part needs.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #8 of 9 (permalink) Old 07-05-2019, 04:14 AM Thread Starter
So testing was fine. I truly think this was a loose connection/water issue. I took all the plastics off the wheeler and hit every single electric connection I could find with a soft wire brush then added dielectric grease. Prior to doing this I was still getting the check engine light on 1st start. After going through the connections the check light was gone.
It's amazing how much dirt was under those plastics lol. I need to buy some extra plastic push ins and start removing plastics and clean everything every other time I ride.
Thanks for the pointers guys.
post #9 of 9 (permalink) Old 07-05-2019, 05:25 AM
What kinda voltage you getting now at 3000 rpm?
