sportsman. 570 balljoints and wheelbearings - Polaris ATV Forum
 1Likes
post #1 of 12 (permalink) Old 09-17-2019, 07:43 AM Thread Starter
ryanr123's Avatar
Question sportsman. 570 balljoints and wheelbearings
what is the best brand (meaning longest lasting) wheel bearings I can put in my sportsman 570. 1400 miles on originals and they are absolutley shot. my front ball joints could use replacement too, so I have the same question. what are the longest lasting ball joints regardless of price, ide rather spend the extra money for em to last longer.
ryanr123 is offline
post #2 of 12 (permalink) Old 09-17-2019, 07:58 AM
bp405's Avatar
For ball-joints I like OEM. I have had the best experience with them. Wheel bearings doesn't seem to matter. Quadboss, OEM, EPI, Allballs, Boss bearing are all relatively the same in my experience. The key to the wheel bearings is the use of a bearing greaser!!!
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
2020 Outlander® 1000R XXC
bp405 is offline
post #3 of 12 (permalink) Old 09-17-2019, 08:01 AM Thread Starter
ryanr123's Avatar
do I need to press the ball joints with a press or can I just use a standard ball joint tool do you know?
ryanr123 is offline
post #4 of 12 (permalink) Old 09-17-2019, 08:14 AM
bp405's Avatar
Is your 570 the strut version?
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #5 of 12 (permalink) Old 09-17-2019, 08:42 AM Thread Starter
ryanr123's Avatar
yes its the base model non xp non power steering
ryanr123 is offline
post #6 of 12 (permalink) Old 09-17-2019, 08:49 AM
chronix79's Avatar
If you can find them for you machine the Frap brand ball joints will way outlast the Polaris ones, price is around the same too.
2014 Scrambler 1000 xp
  • R2C Filter
  • NGK Spark Plugs
  • Cecco Front & Rear A-Arm braces
  • Cecco Pinion Cover
  • 26" Bear Claw HTRs
  • Garage Products Bushings
  • Flexx Bars
  • 2" Rox Risers
  • Elka Stage 4 Shocks
  • Sirius Pro 10" Light bar
  • American Star 12mm Tie Rods
chronix79 is offline
post #7 of 12 (permalink) Old 09-17-2019, 08:54 AM Thread Starter
ryanr123's Avatar
that's awesome because im not impressed with how long the oems lasted, but unfornutelly they haven't made them for the 570 yet it appears
ryanr123 is offline
post #8 of 12 (permalink) Old 09-17-2019, 09:19 AM
bp405's Avatar
If I get 1,000 miles out of a ball-joint I'd be beyond pleased. These EPI's lasted around 700 miles.
As for installing them I've pressed them in if I wasn't replacing the wheel bearing. Since you are I would heat the strut and freeze the ball-joint and it should slide right in. If not have the right sized socket and a persuader ready to give it a little help.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #9 of 12 (permalink) Old 09-17-2019, 09:31 AM Thread Starter
ryanr123's Avatar
thank you for the explanation. ill just order the best ball joints I can based on reviews. ill be back on this forum if I run into a problem because its my first time doing ball joints.
ryanr123 is offline
post #10 of 12 (permalink) Old 09-17-2019, 01:01 PM
Desertdave's Avatar
I truly think its how you ride and where you ride that effects the life of the ball joints and bearings. You say you would be happy to get a 1,000 miles out of a set, I have a 16' sportsman 570 Touring which is a heavy machine and I ride some pretty rough and rocky powerline trails here in Arizona. I have 875 miles on this quad and my entire suspension looks and rides just like the day I bought it. But....I do not ride in creeks, river beds and mud. Just dust is my enemy. I have a 2002 Trail boss 325 that rides these same trails and I am just now having to replace the ball joints. Although this quad has no speedometer, I would bet this quad has 5000+ miles on it.
2016 Sportsman Touring 570 EPS
2002 Trail Boss 325
Desertdave is offline
