XP 1000s cutting out - Polaris ATV Forum
 9Likes
post #1 of 76 (permalink) Old 06-13-2018, 06:10 PM Thread Starter
siverbow's Avatar
I ride with a 2018 sportsman 1000s and today it was cutting out . It was warm day for Montana and we were at about 7000s feet . After It sat for a 3or 4 mi it would start and run.
siverbow is offline
post #2 of 76 (permalink) Old 06-13-2018, 07:17 PM
rutcutter's Avatar
Was it getting a check engine light and posting a code? You have to get the code before you turn the key off after the event happens. Hold the mode button till the "options" menu come up then go to "diagnostics", if the diagnostic screen doesn't come up there are no codes posted.
My name is Mike
These are a couple of my many rides:
2018 Sportsman 1000Xp
Havasu red pearl
3500# Polaris winch with wireless remote
2500# Badland rear mounted winch with wireless remote
Interco Sniper 920 tires
Elka stage 3 shocks
Ricochet 8 piece belly armor with UHMW composite slides
Bad boy airhorn
Tusk street legal kit
Bar end rearview mirrors
LED headlights
LED daylight driving lights
Koplin lock N ride tool/gun holders
Tusk heated grips and thumb warmer
Polaris rear third brake light
Polaris ultimate hand guards and mounts
12" quad row LED light bar
Rear LED flood lights
Bluetooth Firehouse sound system
Gen 3 Spot locator
Garmin 750T GPS/GMRS radio
Go Pro with mounts all over
2004.5 Sportsman 500 50th Anniversary edition
Sadly collecting dust in the shop, now that I got the 1000XP
rutcutter is offline
post #3 of 76 (permalink) Old 06-13-2018, 07:23 PM
Banned
aknawful's Avatar
Next time loosen he gas cap and see if it helps.
aknawful is offline
post #4 of 76 (permalink) Old 06-14-2018, 01:15 PM
sportsmandan's Avatar
throttle cable probably needs adjusting,
my buddy had same issue on his 2016 sportman 1000 xp. His started doing it a 500 miles on quad.
Would start good, ride 500 feet and start cutting out, shut it off, wait a bit, restart, good for 500 and cut out, but it would idle ok.
2016 Scrambler 1000 xp
GSE single slip on muffler
Direction2 flares
2016 Sportsman 570 non ebs
Direction2 flares
ITP XTR radials
sportsmandan is offline
post #5 of 76 (permalink) Old 06-14-2018, 05:20 PM Thread Starter
siverbow's Avatar
It goes to the dealer Friday we see if they can fix it
siverbow is offline
post #6 of 76 (permalink) Old 06-14-2018, 06:30 PM
jjuelmen's Avatar
My 15 was overheating. When temps were approaching 90's I could watch my fan cut out (relocated radiator). The fan pigtail and motor were hotter than hell. Check to see if the fan is running when it cuts out.
2015 Sportsman 1000 Titanium Matte LE
Polaris Body Armor
Polaris Front and Rear Bumpers
Triangle Stealth Snorkel
Powermadd Full Wrap Hand guards
Cecco Frame Braces
Cecco Billet Throttle
RC2 Filter
RJWC Baffle Tech Single Exhaust
Dobeck Programmer
LED Light Bar
RotoPax Fuel Cans
Outkast 3" arched arm lift
2009 Sportsman 550 XP EPS
2003 Scrambler 500 HO (Sold)
2007 Sportsman 800 EFI (sold)
jjuelmen is offline
post #7 of 76 (permalink) Old 06-14-2018, 06:34 PM
2018 1k don't have a throttle cable. Its fly-by-wire.
sportsmandan and jjuelmen like this.
polman500 is online now
post #8 of 76 (permalink) Old 06-15-2018, 01:12 AM
Duse's Avatar
I had the same problem last fall (Limp mode) .Temps were pushing 90. I would get anywhere from 20 foot to 2 miles and it would go to limp mode. Unfortunately it was a H&M trip and I ended up coming home. Took it to my dealer and they couldn't duplicate it.Road all winter without an issue. Then a month ago on a NY trip ,I got to the house ( 4 hour drive,cold and damp)I got unloaded off the bed of the truck,and it started the limp mode again. Weather it was just chance or it was the problem but turning off the 4X4 switch made it stop doing it. Turned the switch on and it went to limp. Did this a few times and it seemed to be the problem. The next morning everything was fine
Duse is offline
post #9 of 76 (permalink) Old 06-15-2018, 02:48 AM
jjuelmen's Avatar
Duse, for your issue with 4X4 I would try changing out your AWD relay if it happens again. I had problems where my machine would turn off and just not start and it was that relay. It was very intermittent. Only reason I was able to track it down was seeing the code on the touch screen being a driver circuit fault. I ended up frying a majority of my relays because my regulator was overcharging the system.
Polaris Body Armor
Cecco Frame Braces
RC2 Filter
Dobeck Programmer
LED Light Bar
RotoPax Fuel Cans
jjuelmen is offline
post #10 of 76 (permalink) Old 06-16-2018, 12:45 PM
Duse's Avatar
GREAT info,will look into that.Thank You
Duse is offline
2005 sportsman 700 efi cutting out goobri Polaris Sportsman 4 12-14-2017 04:58 AM
Sportsman 500 HO Cutting Out Mudman82 ATV New Members 16 12-01-2017 06:53 AM
570 or 1000s sivermax ATV General Discussion 6 11-09-2017 04:44 AM
cutting out and dying snowhite715 Polaris Sportsman 570 1 06-13-2017 07:14 AM
Cutting out under load Sportsman 500 hoffy628 ATV Repair and Maintenance 5 07-12-2016 09:24 AM
