2018 xp1000 touring stalls when fully turned right. - Polaris ATV Forum
post #1 of 13 (permalink) Old 01-26-2019, 10:10 PM Thread Starter
Wanderer's Avatar
Hello everyone. I have an 18 xp1000 touring with about 20 hrs on it, that will stall when it is fully turned to the right only . It will stall whether the bike is in motion or not. I've looked for pinched wires, or wires that may be pulled tight when turning, but everything seems ok. Has anyone come across this before or have any suggestion. I know I can bring it back to the dealer, but I live a far distance away and would prefer not if it's a simple fix. Thanks.
Sent from my SM-N950W using Tapatalk
Wanderer is offline
post #2 of 13 (permalink) Old 01-27-2019, 04:57 AM
20 hours and cutting off when turned...take it to the dealer ASAP.
polman500 is offline
post #3 of 13 (permalink) Old 01-27-2019, 05:32 AM
StarRider's Avatar
If you are using a key chain or have anything dangling from the key get rid of it. The ignition locks are weak and turn off easily if you have a key chain dragging on the tank or anything else. Sometimes just the weight of whats on the key chain swinging around can move the lock enough to shut you down.
2012 550 Sportsman XP EPS Magnetic Metallic
Polaris 2500 winch
Polaris Glacier II+ 60" plow system
FallLine ware bar cutting edge
Polaris Front storage box
Guru front bumper
Wes AR 38 Box/Seat-modified (Lock and Ride)
Rear fender guards with foot pegs (ATV SuperStore)
Ricochet Armor Anodized (ATV SuperStore)
StarRider by Foreigner
Enjoy!
http://www.youtube.com/watch?feature...&v=FDJTsyWVeaM
StarRider is offline
post #4 of 13 (permalink) Old 01-27-2019, 06:34 AM
Duse's Avatar
Have you looked at and adjusted the throttle?(The adjuster is about 6" down from the throttle) Open the throttle cover and see if while turning the handlebars it closes the gap.
Check out this video @ the 4:30 mark he talks about staleing
Duse is offline
post #5 of 13 (permalink) Old 01-27-2019, 06:48 AM
https://www.youtube.com/watch?v=8eWq8CMUtqQ
Yep, didn't think about that Duse. That's something easy you might want to check before taking it in OP.
post #6 of 13 (permalink) Old 01-27-2019, 09:21 AM
bp405's Avatar
Are the 18s throttle wire or a cable?
2011 SportsmanŽ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 SportsmanŽ 570-T
2019 AlumaŽ A8818
2020 OutlanderŽ 1000R XXC (on order, ETA mid-Sept)
bp405 is offline
post #7 of 13 (permalink) Old 01-27-2019, 09:29 AM
18 is fly by wire
latebird is online now
post #8 of 13 (permalink) Old 01-27-2019, 09:58 AM
bp405's Avatar
Thought so. So I would double check all those wires again. Not only for stretch but for wear from turning. Other then that I would disconnect the EPS and turn the bars to see if the machine dies. If it doesn't I would look into a high electrical draw from the power steering unit.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 AlumaŽ A8818
bp405 is offline
post #9 of 13 (permalink) Old 01-27-2019, 11:09 AM Thread Starter
Wanderer's Avatar
Well I feel silly. The lanyard my key was on was ever so slightly tugging at full turn. Fyi my 18 touring has a throttle cable. Maybe the 1up's have drive by wire perhaps? Thanks guys I appreciate the suggestion and saving me a trip to the dealer haha.
Wanderer is offline
post #10 of 13 (permalink) Old 01-27-2019, 02:23 PM
Yep, touring still has a throttle cable. single seater is FBW.
2015 Sportsman etx barely will run, pops, stalls PaYankee Polaris Sportsman 12 10-21-2018 04:38 PM
2018 touring sp rear rack extender fitment br6ad Polaris Sportsman 570 17 09-25-2018 07:14 AM
2018 Polaris Sportsman 850 Touring vs. Can-Am Outlander MAX XT 850: By the Numbers VS_Goose Polaris ATV News 1 04-03-2018 06:49 PM
