Front Diff cover and pinion gear fubar - Polaris ATV Forum
 2Likes
post #1 of 15 (permalink) Old 02-01-2019, 06:29 PM Thread Starter
Hd2500407's Avatar
I was out in the snow today pulling my kids on a sled. I heard a distinct crack from the front end. (Note was in AWD) I got off to look and see if i hit something. Well nothing hit but fluid pouring from my broken diff cover. My pinion gear was still inside the gear case so I limped it back to my garage. I removed the two bolts not holding anything lower two. I then removed the upper two that still was holding my pinion gear in place. I removed the crush pin and removed drive shaft. Now I was able to remove the pinion gear. I observed two teeth chipped up. I checked the ring gear and it looked ok. Well this is where I get pissed. I purchased this quad with 148miles on it from a Polaris Rep. Never titled till I purchased it. Its a 2017 Sportman Xp1000 decked out by rep. Winch, plow, led lights after market wheels and tires brush gaurds rear cargo system. I mean awesome quad. Ive maybe put 300 miles on it mainly deer season and deer scouting. No riding adventures never buried in mud nothing. Wife and kids prob put half the miles on it doing yard work.
Well I figured id get online and order some parts. Ie: cover and pinion gear. Well billet covers are everywhere. As for the pinion gear thats a big fat your screwed by polaris. I called two local dealerships they quoted me 664$ for entire new diff unit. When I pull up the diff parts cache it clearly shows all parts labeled individually. Actually the pinion gear is #14. When I question every shop or online source. They just say I gotta order entire gear box unit.
Im to this point. Order a new billet cover put chipped pinion gear back in and let it ride. Why not if I have to buy complete assembly if it breaks oh well at least ill have a new billet cover.
Any thoughts or help would be greatly appreciated. I turned to this forum when I initially started researching my atvs failure.
ID:	115571   Click image for larger version
ID:	115573   Click image for larger version
Hd2500407 is offline
post #2 of 15 (permalink) Old 02-01-2019, 09:48 PM
bp405's Avatar
I've noticed this not being able to buy front diff pieces just the whole unit. There has to be a way the cross reference parts through Hillard. I know guys were buying parts from John Deere because their diffs are also built by Hillard.
2011 SportsmanŽ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 SportsmanŽ 570-T
2019 AlumaŽ A8818
2020 OutlanderŽ 1000R XXC (on order, ETA mid-Sept)
bp405 is offline
post #3 of 15 (permalink) Old 02-02-2019, 03:34 AM Thread Starter
Hd2500407's Avatar
Ive done hours of research. Bp405 suggested contacting Hilliard company. Well ive sent them an email and will be calling them next week. Funny side note they make parts for John Deere. Well guess what, my 2015 Jd 1025r had catastrophic drive shaft failure with like 120hrs on my sub compact tractor. I replaced the complete drive shaft and universal for like $125. Ill keep every one uodated what they say. Thanks again bp405.
post #4 of 15 (permalink) Old 02-02-2019, 03:39 AM
bp405's Avatar
No problem!!! Hey on a side note, what's the best place to order JD OEM parts. Haven't found any places online I like. I have an x748 with the Yanmar in it.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 AlumaŽ A8818
bp405 is offline
post #5 of 15 (permalink) Old 02-02-2019, 07:07 AM
[QUOTE=bp405;1411561]No problem!!! Hey on a side note, what's the best place to order JD OEM parts. Haven't found any places online I like. I have an x748 with the Yanmar in it.[/QUOTE
This is best place I've found bp. Ordered a couple batches of diff. rebuild parts from them.
https://www.greenfarmparts.com/?mscl...20Farm%20Parts
bp405 likes this.
polman500 is offline
post #6 of 15 (permalink) Old 02-02-2019, 07:22 AM
Op, you might be ok with just smoothing up the pinion gear and reusing it but I think you may be misunderstanding the parts guys.
Number 14 is the complete assembly of the pinion ONLY for $660 something...pinion gearshaft, pinon cover and associated seals and bearings.
A complete new front gearcase is $1200+ if reusing the old pinion destroys the rest of the gearcase.
Just an FYI in case you were mistaken.
post #7 of 15 (permalink) Old 02-02-2019, 08:55 PM Thread Starter
Hd2500407's Avatar
Part #3235636 part#14 Polaris parts cache. K-gear pinion parts. Look how many models this part fits.
ASM., GEAR HOUSING AND PINION GEAR (3235636)polarispolaris 3235636 ASM., GEAR HOUSING AND PINION GEAR
WARNING
3235636
See Price in Cart$664.99
Quantity*Expected to Ship in 3-6 Days
Report a Problem*Email a Question
This part fits these bikes:
POLARIS ACE 570 EFIYear:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a16daa57a5/a7/l2 (49rgrtransintl13900xp)
POLARIS 850 SPORTSMAN TOURING SPYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sye85as (atvgearcase1333392)Year:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18sye85bb (101305)
POLARIS ACE 325 EFIYear:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a16daa32a1/a7 (49rgrtransintl13900xp)
POLARIS ALL OPTIONS RANGER CREW 1000XP PSYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r17rtad1a1 (49rgrtransintl13900xp)
POLARIS POLARIS GENERAL 1000 EPSYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rua87a1/b1/va87a1/b1 all options (49rgrtransintl13900xp)
POLARIS RANGER 1000 DIESELYear:*2015Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r15rta/e87 all options (49rgrtransintl13900xp)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rtad1a1 (49rgrtransintl13900xp)Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r17rtad1a1 (49rgrtransintl13900xp)
POLARIS RANGER 1000 DIESEL CREWYear:*2015Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r15ruad1aa (49rgrtransintl13900xp)Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r17rtad1a1 (49rgrtransintl13900xp)
POLARIS RANGER 570 FULL SIZEYear:*2016Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rta57a1/a4/a9/b1/b4/b9 (49rgrtransintl15570)
POLARIS RANGER 570, FULL SIZEYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r17rca57a1/a4 (49rgrtransintl13900xp)
POLARIS RANGER CREW 900Year:*2015Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r15rua87/e87/yaa/zac all options (49rgrtransintl13900xp)
POLARIS RANGER CREW 900 ALL OPTIONSYear:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rua87a1/b1/va87a1/b1 all options (49rgrtransintl13900xp)
POLARIS RANGER ETXYear:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r15rma32aa/aj (49rgrgearcase1333391)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rma32a1/a2 (49rgrtransintl13900xp)
POLARIS RANGER EVYear:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rma57a1/a4/a9/l1/e57as (49rgrtransintl13900xp)Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r17rma57a1/a9/e57ak (49rgrtransintl13900xp)
POLARIS RANGER EV LI-IONYear:*2016Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rma57f1/n1/sf1 (49rgrtransintl13900xp)
POLARIS RGR 1000 XPYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r17rma57a1/a9/e57ak (49rgrtransintl13900xp)
POLARIS RGR 499, 500, ETX ,2WD HDPEYear:*2017Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rma57f1/n1/sf1 (49rgrtransintl13900xp)
POLARIS RGR 570Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r17rma57a1/a9/e57ak (49rgrtransintl13900xp)
POLARIS RGR 570 (R15RMA57AA/AR/AZ/AC/LA/H57AR)Year:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r15rma32aa/aj (49rgrgearcase1333391)
POLARIS RGR 570 (R16RMA57A1/A4/A9/L1/E57AS/A9/H57AR)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rma57a1/a4/a9/l1/e57as (49rgrtransintl13900xp)
POLARIS RGR 570 EFI CREWYear:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rna57a1/a9/a4/e57ah (49rgrtransintl13900xp)
POLARIS RGR 570 FULL SIZEYear:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r15rna57aa/ac/ar/e57as (49rgrgearcase1333391)
POLARIS RGR 570 FULL SIZE CREWYear:*2016Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rva57a1/b1/e57a9/b9 (49rgrtransintl15570)
POLARIS RGR 900 XPYear:*2015Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r15rta/e87 all options (49rgrtransintl13900xp)Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r17rta87a1/b1/a9/b9 (701345)
POLARIS RGR 900 XP ALL OPTIONSYear:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - r16rta87a1/a4/a9/b1/b4/b9 (49rgrtransintl13900xp)
POLARIS RZR 1000 60 INCH ALL OPTIONSYear:*2016Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - z15vha57aj/e57as/ak (49rgrtransintl13900xp)
POLARIS RZR 1000 60 INCH PSYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - z16vha57a2 (49rgrtransintl13900xp)
POLARIS RZR 4 900Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - z16vha57fj (49rgrtransintl13900xp)
POLARIS RZR 4 900 (Z16VCE87AB/AR)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - z15vha57fj (49rgrtransintl13900xp)
POLARIS RZR 570 (Z15VHA57AJ/E57AS)Year:*2015Part:*KIT, GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - z15vha57aj/e57as/ak (49rgrtransintl13900xp)
POLARIS RZR 570 (Z16VHA57A2/EAK/AS)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - z16vha57a2 (49rgrtransintl13900xp)
POLARIS RZR XP 4 1000Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - z16vha57fj (49rgrtransintl13900xp)
POLARIS RZR XP4 TURBOYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - z16vha57a2 (49rgrtransintl13900xp)
POLARIS SCRAMBLER 1000 MDYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sve95nm
POLARIS SCRAMBLER 1000 TRACTORYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17svt95c2Year:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18svs95cr/er (101305)
POLARIS SCRAMBLER 1000 XP ZUGYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17svs95fmYear:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18svs95fr (101305)
POLARIS SCRAMBLER 850Year:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a15sva85ad (49atvgearcase1333391)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a16sva85a2 (1333391)Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sva85a2 (1333391)Year:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals (to 8/7/2017) - a18sva85b5 (101322)
POLARIS SCRAMBLER XP 1000Year:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a15sve95aw (49atvgearcase1333391)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a16sve95aa/amYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sve95amYear:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals (to 8/7/2017) - a18sve95br (101322)
POLARIS SPORTSMAN 1000 HIGH LIFTERYear:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18sxm95al (101322)
POLARIS SPORTSMAN 1000 MDYear:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a15sxe95hk (49atvgearcase1333392)
POLARIS SPORTSMAN 1000 XPYear:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a15sxe95ac/ak/aw/l95am (49atvgearcase1333392)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a16sxe95ag/ar/d95a9Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sxd95a9/sxe95ac/al (atvgearcase1333392)Year:*2018Part:*ASM., GEAR HOUSING AND PINION GEARPart Group:*drive train, front gearcase internals - a18sxd95b9/sxe95br/bc/be (101305)
POLARIS SPORTSMAN 1000 XP MDYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sxe95nl (atvgearcase1333392)
POLARIS SPORTSMAN 1000 XP TRACTORYear:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18sxs95cc/cr/er (101305)
POLARIS SPORTSMAN 1000 XP ZUGYear:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18sxs95fr (101305)
POLARIS SPORTSMAN 850 HIGH LIFTERYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sxe95nl (atvgearcase1333392)Year:*2018Part:*ASM-GEARCASE HOUSING,PNN GEARPart Group:*drive train, front gearcase internals - a18sxn85a8 (101322)
POLARIS SPORTSMAN 850 SPYear:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a15sxe85as/am (49atvgearcase1333392)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a16sxe85as/am/ab (atvgearcase1333392)Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sxe85ab/am/as/a9 (atvgearcase1333392)Year:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18sxe85bm/bs/b9 (101305)
POLARIS SPORTSMAN 850 TOURING SPYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sye85as (atvgearcase1333392)Year:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18sye85bb (101305)
POLARIS SPORTSMAN TOURING 1000Year:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a15sye95ax/l95ap (49atvgearcase1333392)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a16sye95ak/apYear:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sye95akYear:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18sye95bu (101305)
POLARIS SPORTSMAN TOURING 850 SPYear:*2015Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a15sye85as/av (49atvgearcase1333392)Year:*2016Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a16sye85as (atvgearcase1333392)
POLARIS SPORTSMAN TOURING TRACTOR 1000Year:*2017Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a17sys95ck (49atvgearcase1333392)Year:*2018Part:*K-GEAR HOUSING & PINIONPart Group:*drive train, front gearcase internals - a18sys95cu/eu (101305)
post #8 of 15 (permalink) Old 02-03-2019, 02:52 AM
You might check with Powersports Nation to see if they would have a good used one?
post #9 of 15 (permalink) Old 02-03-2019, 05:39 AM
rutcutter's Avatar
It says a High Lifter in your list, there is one on Ebay, comparing the picture you posted and the one on Ebay it looks like the bearing are different.
Some say my link isn't working. This is the listing number, type it into the search on Ebay 183500164757
https://www.ebay.com/itm/Polaris-16-...z5yx:rk:4:pf:0
My name is Mike
These are a couple of my many rides:
2018 Sportsman 1000Xp
Havasu red pearl
3500# Polaris winch with wireless remote
2500# Badland rear mounted winch with wireless remote
Interco Sniper 920 tires
Elka stage 3 shocks
Ricochet 8 piece belly armor with UHMW composite slides
Bad boy airhorn
Tusk street legal kit
Bar end rearview mirrors
LED headlights
LED daylight driving lights
Koplin lock N ride tool/gun holders
Tusk heated grips and thumb warmer
Polaris rear third brake light
Polaris ultimate hand guards and mounts
12" quad row LED light bar
Rear LED flood lights
Bluetooth Firehouse sound system
Gen 3 Spot locator
Garmin 750T GPS/GMRS radio
Go Pro with mounts all over
2004.5 Sportsman 500 50th Anniversary edition
Sadly collecting dust in the shop, now that I got the 1000XP
rutcutter is offline
post #10 of 15 (permalink) Old 02-03-2019, 06:13 AM
Yep, that one has a double row bearing for more support I suppose. It says at the bottom of the ad to contact them for different models so they may be able to hook you up OP.
Let us know what you find out if you do contact them.
Front diff pinion axle Deebo82 ATV Repair and Maintenance 3 01-26-2019 03:38 PM
Front diff pinion cover upgrade boot215 Polaris Highlifter 10 01-05-2018 01:17 AM
850 and 1000 front gearcase pinion cover recall Durf577 Polaris Highlifter 35 04-18-2017 11:44 PM
Front Diff. Pinion cover help Jed. Polaris Scrambler XP 7 04-12-2017 06:31 AM
Front differential pinion cover exploaded! Only 60 miles gator800r Polaris Sportsman XP 1000 15 12-29-2016 07:48 AM
