10,000 Miles - Still going! - Polaris ATV Forum
 7Likes
  • 2 Post By NWISCOSportsman
  • 3 Post By NWISCOSportsman
  • 1 Post By NWISCOSportsman
  • 1 Post By PoPo3
post #1 of 9 (permalink) Old 03-13-2019, 06:16 AM Thread Starter
NWISCOSportsman's Avatar
My 2015 1000 is approaching 10,000 miles (currently right around 9500, so first few weeks this spring should get it there). If anybody cares, here's the major issues I've had:
1. Transmission Failure last fall - loud clanking while doing a hillclimb followed by BOOM and then no forward, reverse - nothing. That was a fun 60 mile tow back to camp. This is the only time the machine left me stranded luckily!
2. Rear suspension mounting ears close to ripping off frame. I noticed this while swapping out the transmission - saw cracks in the welds. There was like NO penetration from the factory welds to the frame, the reason they were coming off. I worked with a buddy to re-weld and strengthen and also added in the Cecco Braces I had for the back end at that time. should be good to go now
3. I replaced all bushings like 2 times in the first 4000 miles or something like that. Went to JCCapri bushings after that and it's been fine since!
4. Front diff never exploded - I put the upgraded pinion cover on early in it's life and it has held up well (thankfully!)
5. 3rd set of rear tires now - Kenda bearclaws last but I still burn through the rear tires a lot faster than the fronts
6. Voltage regulator went out twice, I'm on my 3rd now. They don't seem to like sitting above the radiator! This time I went RMStator we'll see how it holds up
7. NO Motor issues - it's still super solid, just regular maintenance. Spark plugs twice so far, I'll probably put another set in early this spring
8. Numerous exhaust issues early in its life due to the bad Polaris design. Fixed after I went HMF exhaust
9. Replaced all the wheel bearings around 8K miles from what I remember. These things last too if you're not running around in the mud/grit all the time.
10. Rear factory shock blew out on a trail - found a used one on ebay and it's been fine since
11. Front lower control arm (factory one cracked after a run in with a boulder - completely my fault)
12. Front coil spring snapped - was out in the black hills with a heavier load on the front end - there were some drops I came off of pretty hard and I think this caused the spring to give up the ghost
Last summer a clutch kit was done on it @ RVS Performance - that clutch kit absolutely ROCKS and the machine still has GOBS of power. I've replaced the drive belt pre-emptively like 3 times, and think I'll do it again this spring.
I'll also have Ryan @ RVS tune it this spring. I have a piggyback on there now for the HMF exhaust - which causes it to run like GARBAGE at altitude. The RVS tune and removing piggyback should help out with this - planning trips to Colorado and South Dakota this summer so it will be nice to have the tune done before then.
All in all, I love this machine and even though you have to maintain them quite a bit to make them last, I always go by the idea that you have to pay to play. I don't think any other machines would have been much better than this one in terms of durability. (well maybe a Yamaha/Honda/Suzuki but they're so boring!)
Any others getting up there in the mileage/hours on their units?
TigerTool and SlowRoller like this.
2015 Sportsman 1000XP
Polaris Interactive Digital Display
HMF Titan Exhaust (Ceramic Coated) W/Optimizer
Kenda Bearclaw HTR's
Polaris Front/Rear Brushguards
Polaris Front/Rear Cargo Boxes
RotoPax 2 Gallon w/front Mount
Polaris LED headlight Conversion
Sirius PRO 6" LED lightbar
Cecco Front/Rear Frame Braces
JCCapri Full Bushing Kit
8250 Miles and Counting...
Past:
2013 Sportsman 500 H.O.
NWISCOSportsman is offline
post #2 of 9 (permalink) Old 03-13-2019, 09:05 AM
MegaBUD's Avatar
Wow sounds great, 10k miles is a lot, any idea how much money you put on it in repairs/maintenance?
2018 Sportsman 1000 Havasu Red Pearl
2014 Sportsman 570 Indy Red (sold)
MegaBUD is online now
post #3 of 9 (permalink) Old 03-13-2019, 10:00 AM
MustBeNice's Avatar
Way to go!
Matthew "MustBeNice"
MustBeNice is offline
post #4 of 9 (permalink) Old 03-13-2019, 11:08 AM Thread Starter
Looks to be around $6,500 so far based on my records - that includes fluids/filters and all parts such as exhaust and replacement parts. Did almost all the work and maintenance myself except for clutch kit and one full service at the dealer because I was feeling lazy. If all the work was done by a shop, I'd bet I'd easily be into the $10-$15K range
I'm just super excited I've kept myself from trading it in and buying a new one - it's been nice having this one paid off for a couple years now! Now I'm hoping to hit 20K miles in the next 3-4 years of riding. I'm almost curious to see how far this one can go.
Past:
post #5 of 9 (permalink) Old 03-13-2019, 11:09 AM
SlowRoller's Avatar
Awesome! Nothing to bad either, tranny sucks but 10k on one of these is a lot! Sounds like you use it to the fullest as well. Post some pics!
18' 850SP
SlowRoller is offline
post #6 of 9 (permalink) Old 03-13-2019, 11:19 AM Thread Starter
Here's a few - One in Colorado, one in Wisconsin getting some work done to it (had just finished putting in rear wheel bearings I think) and one in Wabasha MN with my buddy's RZR out for the ride too
ID:	116607   Click image for larger version
ID:	116609   Click image for larger version
SlowRoller likes this.
Past:
post #7 of 9 (permalink) Old 03-13-2019, 02:49 PM
Duse's Avatar
Thats impressive
Duse is offline
post #8 of 9 (permalink) Old 03-13-2019, 03:13 PM
PoPo3's Avatar
I did 9986 miles on a Honda I had some years ago. And the only expense other than gas was TIRES. I know of a guy over in Richfield UT that has over 30,000 on his Honda. Last I heard he put 4 new shoes on the bike and he said he couldn't get the price of the tires if he sold the bike.
PoPo3 is offline
post #9 of 9 (permalink) Old Today, 07:37 PM
crazyflyboy30's Avatar
Very glad to hear about a Polaris Sportsman 1000XP with 10,000 miles.Mine will never see that many miles because no time to ride.
crazyflyboy30 is online now
240 Miles in a single weekend BruteForce ATV Ride Report 0 09-26-2018 02:21 AM
550XP EPS touring with 4600 miles...worth considering? flyinghigh Polaris XP 14 10-24-2017 10:49 AM
How many miles you got? Porky ATV General Discussion 17 11-07-2016 01:29 PM
How many miles 570 Greyghost01 Polaris Sportsman 570 9 05-18-2016 10:01 AM
How many miles are too many buying a used ATV Vulcan700 ATV General Discussion 23 12-31-2015 04:51 AM
