2017xp 1000 creeping at idle - Page 2 - Polaris ATV Forum
 6Likes
post #11 of 29 (permalink) Old 03-18-2019, 11:53 AM Thread Starter
wkeggenhoff's Avatar
Do you have to remove the spider from the shaft to change the one way bearing ? What year scrambler beraring did you order ?
2017 Xp 1000 Sportsman LE Matte Cooper
2008 843cc Yamaha Grizzly
wkeggenhoff is offline
post #12 of 29 (permalink) Old 03-18-2019, 12:02 PM Thread Starter
post #13 of 29 (permalink) Old 03-18-2019, 12:09 PM
bp405's Avatar
???? Didn't think the Scramy had a one way bearing???
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #14 of 29 (permalink) Old 03-18-2019, 03:00 PM
Deucer's Avatar
Originally Posted by wkeggenhoff View Post
Do you have to remhttps://www.ebay.com/i/283389791182?chn=psove the spider from the shaft to change the one way bearing ? What year scrambler beraring did you order ?
yes you have to take off the spyder. It takes a special tool. I made my own but for a one time deal the dealer will crack it apart for you and put in the bearing. Not really a big deal once you have it all tore down.
D
Deucer is offline
post #15 of 29 (permalink) Old 03-18-2019, 03:01 PM
Deucer's Avatar
It doesn't. But if you want TWO WAY bearing in your sportsman. You gotta get one from a scrambler.
Deucer is offline
post #16 of 29 (permalink) Old 03-19-2019, 03:29 AM Thread Starter
post #17 of 29 (permalink) Old 03-19-2019, 03:32 AM Thread Starter
Ok thanks. Used to have the tool years ago when i used to service my polaris snowmoile clutches. Sold them all
post #18 of 29 (permalink) Old 03-19-2019, 09:36 AM
sportsmandan's Avatar
the Scrambler clutch free roles with no resistance after the belt lets go. You can than free roll down a long steep hill at the speed u choose using rear brakes.
2016 Scrambler 1000 xp
GSE single slip on muffler
Direction2 flares
2016 Sportsman 570 non ebs
Direction2 flares
ITP XTR radials
sportsmandan is offline
post #19 of 29 (permalink) Old 03-19-2019, 03:41 PM
Deucer's Avatar
Or use the front brake with ADC turned on. That way the rear end doesn't do the well known "Polaris skid" out of control.
It still rolls free under about 6 mph but you can control your speed with the brakes instead of the throttle to control your descent. I am pretty sure that is why my One Way bearings only last about 1000 miles. We ride some really slow rocky trails here in the Rocky Mountains and the one way takes a real hammering engaging and dis-engaging several thousand times a ride.
I like the scrambler bearing way better for my type of riding. Last longer too.
D
Opps, forgot you were on a scrambler!! No ADC for you. But, works good for me.
Deucer is offline
post #20 of 29 (permalink) Old 03-19-2019, 04:51 PM
D
scramblers do not have ADC or EBS, its pretty much all flat land up here where i live so ebs is just a nuisance.
of course its needed in different terrain.
Direction2 flares
Direction2 flares
ITP XTR radials
NGK plugs Happyman Polaris Sportsman XP 1000 41 07-12-2019 03:44 AM
Common Carb Issues pfunk76 ATV Repair and Maintenance 117 03-30-2019 08:09 AM
2015 Sportsman etx barely will run, pops, stalls PaYankee Polaris Sportsman 12 10-21-2018 04:38 PM
xp 1000 idle lopes when on high idle! shane-o ATV Repair and Maintenance 0 04-12-2018 06:20 AM
