2" lift kit installed - Polaris ATV Forum
post #1 of 8 (permalink) Old 04-08-2019, 07:01 AM Thread Starter
rutcutter's Avatar
Last week I installed a 2" lift and a set of 29" takeoffs wheels and tire from a RZR. I was amazed this past weekend that I never took a hit on the skid plates. I ended up with just over 4" of lift with the kit and tires. I can actually see the full arch of the A frames now. Had no rubbing issues with the tall tires. Handling did change just a tad, but nothing drastic. By the end of the weekend it just felt like it always did. It's a good inexpensive, worth doing upgrade.
This is the lift kit I installed, it is very robust and easy to install.
https://www.ebay.com/itm/ATV-2-SUSPE.../262637647262?
My name is Mike
These are a couple of my many rides:
2018 Sportsman 1000Xp
Havasu red pearl
3500# Polaris winch with wireless remote
2500# Badland rear mounted winch with wireless remote
Interco Sniper 920 tires
Elka stage 3 shocks
Ricochet 8 piece belly armor with UHMW composite slides
Bad boy airhorn
Tusk street legal kit
Bar end rearview mirrors
LED headlights
LED daylight driving lights
Koplin lock N ride tool/gun holders
Tusk heated grips and thumb warmer
Polaris rear third brake light
Polaris ultimate hand guards and mounts
12" quad row LED light bar
Rear LED flood lights
Bluetooth Firehouse sound system
Gen 3 Spot locator
Garmin 750T GPS/GMRS radio
Go Pro with mounts all over
2004.5 Sportsman 500 50th Anniversary edition
Sadly collecting dust in the shop, now that I got the 1000XP
rutcutter is offline
post #2 of 8 (permalink) Old 04-08-2019, 09:12 AM
How much did the lift stretch the OEM axles rutcutter?
I wouldn't care to get a little more clearance but if its gonna be hard on axles I don't know if I want to do it. I'm running 28's and get a little rub on the flares under compression. Thought I might just turn the springs up a little to see if that helps. I'm still on the lowest setting cause I love the ride.
Of course I see you have Elkas I want too. They worth the green?
polman500 is offline
post #3 of 8 (permalink) Old 04-08-2019, 02:14 PM Thread Starter
rutcutter's Avatar
I am not sold on the Elka's. They are an improvement over stock but were dang hard to get to work/adjusted for my riding style. I don't think the axles are binding at all, yes they have a steeper angle but I don't really think they are stretched length wise any.
My name is Mike
Havasu red pearl
Elka stage 3 shocks
Bad boy airhorn
LED headlights
Gen 3 Spot locator
post #4 of 8 (permalink) Old 04-09-2019, 06:19 AM
Deucer's Avatar
I was looking at the same lift kit. How is the angle on the axles afterword? I don't want to be replacing axles every 1000 miles or so.
D
Deucer is offline
post #5 of 8 (permalink) Old 04-09-2019, 09:30 AM Thread Starter
rutcutter's Avatar
D
The axles are not maxed, I have around 3 inches of sag when jacked up. Right now I have a lot of preload adjusted into my Elka's. I was trying to get the ride height back to stock. With the lift I can back it off some to get a little better ride and axle angle.
My name is Mike
Havasu red pearl
Elka stage 3 shocks
Bad boy airhorn
LED headlights
Gen 3 Spot locator
post #6 of 8 (permalink) Old 04-13-2019, 08:45 PM
Oweee's Avatar
Hey ruttcutter I am struggling with the elkas as well how much more preload did you end up with or how did u adjust?
Thanks O.
Oweee is offline
post #7 of 8 (permalink) Old 04-14-2019, 07:01 AM Thread Starter
rutcutter's Avatar
My rears have only about 1" more adjustment. The fronts have around 2" more. I used the tool that came with them to adjust them. Make sure you jack up the machine before adjusting. Originally when I put them on I lost 3" of the OEM ride height. The ride was soft and cushy like the stock ride. Most trails I ride here in Utah are very rocky and I was bottoming out a lot. That is why I almost maxed out the preload on the Elkas. I did get the ride height back and a touch more by doing the preload adjustment. The ride stiffened alot over the OEM ride, it is not an issue for me because I am a very aggressive rider and these 1000s are heavy and when mine is fully loaded it has to be pushing close to 7-8 hundred pounds (a guess). I was still bottoming out.
Since installing the lift I stopped probably over 90% of the bottoming out. This coming week will be a good test as I will be riding a VERY rocky area in southern Utah. I am going to back off a little of the preload to try and soften the ride up a little.
As of right now I love the lift, and the look the lift gives the machine. I was worried about raising the center of gravity, but last week I was riding the slick rock in Moab on very steep off camber angles and had no problems at all.
My name is Mike
Havasu red pearl
Elka stage 3 shocks
Bad boy airhorn
LED headlights
Gen 3 Spot locator
post #8 of 8 (permalink) Old 04-14-2019, 01:20 PM
Oweee's Avatar
Ok thanks for info I have exact same quad as u and I bottom out way more with the elkas. I guess I will have to crank them up more and maybe add that 2 inch lift. I am running 26 inch terra cross . I was riding in Arizona alot this winter and I couldn't believe how many rocks in the middle of the trail were hitting my skid plate. I was almost gonna put my stickers back on. Thanks again.
O.
Oweee is offline
Thoughts on this 2" lift kit justcallmejoe Polaris Sportsman 570 3 04-12-2019 10:36 PM
F/S RZR 570 Racer Tech 2" Lift Kit (Brand New) RND ATV Parts for Sale 2 05-13-2018 07:44 PM
Perfex 2" lift kit? Rio Polaris XP 7 11-07-2016 08:50 AM
2" lift kit carch4 Polaris ATV How-Tos 1 03-21-2016 07:05 AM
2" lift kit carch4 ATV General Discussion 0 03-20-2016 04:48 AM
