Sportsman 1000 fan removal - Polaris ATV Forum
 3Likes
  • 1 Post By polman500
  • 1 Post By camlaw
post #1 of 10 (permalink) Old 06-23-2019, 05:21 PM Thread Starter
camlaw's Avatar
Fan seized up..can fan shroud come off without removing radiator ?
camlaw is offline
post #2 of 10 (permalink) Old 06-29-2019, 03:42 PM Thread Starter
camlaw's Avatar
Wow,,crickets are even making noise ..discovered one of my fan blades broke off..got stuck between fan and radiator... preventing fan from turning...nothing got in there to break fan..sticks,,etc..just hit a water hole too fast I guess. .while fan was on .fan shroud is not as easy to take out as other machines I've had ..it's snapped onto rad...and 2 bolts..need to remove plastic..to get it off ..p.i.t.a
Still under warranty..but dealer says..doubt it will be warrantied...$250.00 for new fan...I'm going outside now to kick a tree. .
camlaw is offline
post #3 of 10 (permalink) Old 06-30-2019, 04:14 PM Thread Starter
camlaw's Avatar
ID:	118627   Click image for larger version
camlaw is offline
post #4 of 10 (permalink) Old 06-30-2019, 04:16 PM Thread Starter
camlaw's Avatar
If ya ever need to pull fan...at a minimum..remove top rad hose...and the front sub frame..headlights..front plastic
camlaw is offline
post #5 of 10 (permalink) Old 06-30-2019, 04:19 PM
gearheadesw1's Avatar
One of my fans on my HL1000 crapped out quite a while back, the Polaris version is way expensive. I found a Spall (?) fan on eBay that has worked great, I slather lots of water dispersing lube on them now, seems to help.
must modify
gearheadesw1 is online now
post #6 of 10 (permalink) Old 06-30-2019, 04:43 PM Thread Starter
camlaw's Avatar
I'm gonna look into the spal fans..don't want to spend money on oem and have it break again
camlaw is offline
post #7 of 10 (permalink) Old 06-30-2019, 05:13 PM
Here's a good looking used one from Canada for $100 less than new camlaw.
https://www.ebay.com/itm/2018-POLARI...dAUbx#viTabs_0
gearheadesw1 likes this.
polman500 is offline
post #8 of 10 (permalink) Old 06-30-2019, 05:17 PM
Or here's the Spal for close to the same price.
https://www.ebay.com/itm/2014-2019-P...wAAOSweedctNgE
post #9 of 10 (permalink) Old 06-30-2019, 05:46 PM Thread Starter
camlaw's Avatar
Thanks...good info
camlaw is offline
post #10 of 10 (permalink) Old 07-07-2019, 05:45 PM Thread Starter
camlaw's Avatar
Originally called dealer about broken fan .he wasn't sure if it would be warrantied...so being impatient I started taking it out myself ..figured I'd just buy one...but he called me..told me Polaris would warranty it. So thanks to dealer and Polaris for taking care of the issue. I lucked out. When blade broke. Didn't cause much damage to radiator..just couple of fins pushed over. But these radiators list for $650.00,,,,little shocked. .so need to watch hitting water or mud when fan is engaged. I've read to install off/ on switch for fan...but I'm still under warranty
camlaw is offline
