2017/18 60kph speed limiter - Polaris ATV Forum
 1Likes
  • 1 Post By polman500
post #1 of 8 (permalink) Old 10-02-2019, 09:56 AM Thread Starter
GBMUD's Avatar
Hi all. I just bought a slightly used 1000XP Here in the UK. It is EU homologated as a tractor (T3) and has a 60 kph/37mph speed limiter. Any clues on how to lift this limit, or is it a dealer only job?
If I cannot raise the limit myself, any ideas where the speed sensor is, and will disconnecting it make any important differences - other than hopefully eliminating the limiter...
Cheers
Chris
GBMUD is offline
post #2 of 8 (permalink) Old 10-02-2019, 11:40 AM
Cheers
Chris
It being an EU requirement I doubt the dealer would be allowed to change it.
There is a recent thread on here somewhere of a guy in Norway I think on the same subject. He got some info about an add-on to fool the speedo but it also makes the speedo read wrong.
Here is a link I found with a quick search that will reprogram the ECU to take the limiter off.
https://www.haldexrepairs.co.uk/shop...moval-service/
polman500 is offline
post #3 of 8 (permalink) Old 10-02-2019, 12:57 PM
MegaBUD's Avatar
Can't you just flash the ECU? its like 300-500$.
2018 Sportsman 1000 Havasu Red Pearl
2014 Sportsman 570 Indy Red (sold)
MegaBUD is online now
post #4 of 8 (permalink) Old 10-02-2019, 04:18 PM
Yep, the link I gave him is for just that. That place advertises that they will reprogram his ECU to take the EU mandated low speed 37 mph speed limiter function out. The EU mandates the limiter to classify his machine as a "tractor''. The add says they charge 187.75 British pounds. That is around $231 U.S. dollars according to my calculator.
MegaBUD likes this.
post #5 of 8 (permalink) Old 10-07-2019, 07:35 AM Thread Starter
GBMUD's Avatar
Thanks for the replys guys. I asked the (official Polaris) dealer who says that they are not able to lift the limiter.
I had already found the link to the form that can remove the limiter. Their blurb says that they need to open the ECU to do it - which will then invalidate the warranty - so I am not keen on that solution.
Simply disconnecting the speedo transducer causes limp mode and the MIL light. I have ordered a Healtech SpeedoHealer which claims to lift the limit - by modifying the speed signal and lying to the ECU.
Thanks again
Chris
GBMUD is offline
post #6 of 8 (permalink) Old 10-07-2019, 08:20 AM
bp405's Avatar
I know you can order a separate ECU from RVSPerformance. This way you can have all the benefits of a tuner ECU while keeping your factory ECU intact and untouched.
2011 SportsmanŽ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 SportsmanŽ 570-T
2019 AlumaŽ A8818
2020 OutlanderŽ 1000R XXC (on order, ETA mid-Sept)
bp405 is online now
post #7 of 8 (permalink) Old 10-08-2019, 09:49 AM
lamel's Avatar
i have EU homologated 2018 limited 80kph ,living in belgium ,mine does not have any limitation. dealer says you have to cut something out of the harness. module, and I thought us software in ecu . 100% sure you have to cut something out of the wire harness
lamel is offline
post #8 of 8 (permalink) Old 10-10-2019, 09:21 AM
Jazzy's Avatar
Probably a different model, sold as L7 instead of T3. But that's my understanding as well, there's a circuit in the wire harness that can be cut.
Have: 2019 Scrambler XP 1000 - 2016 Yamaha YFZ-450r
Had: 2006 Barossa - 2007 Raptor 350 - 2004 Warrior - 1996 Blaster - 2001 Raptor 660 - 1991 Banshee - 1998 Blaster - 2009 Raptor 250 - 2007 Raptor 700SE - SMC Extreme 250 - 2007 Renegade 800 - Yamaha Breeze (2x) - 2011 Raptor 250 - 2008 Outlander 800 Max LTD - 2008 YFZ450 - 2011 Raptor 250 - 1999 Eton AXL90 - 2007 YFZ450SE - 2011 Outlander 800 Max LTD - 2007 Raptor 250 SE - Suzuki LT50 - 2013 Outlander 1000 Max XT-P - 2009 Outlander 650 Max XT - Suzuki LTR450 - 2014 Outlander 1000 Max XT-P - 2009 Raptor 250 - YFZ450 with RMZ250 engine - 2017 Outlander 1000 Max XT-p
Jazzy is offline
