Still having 4wd issues.... - Polaris ATV Forum
post #1 of 8 (permalink) Old 05-20-2018, 04:13 AM Thread Starter
DZG400's Avatar
01 sportsman 500 H.O
My 4wd will not engage. Last night i pulled the driverside (left if your on it) hub apart. Found metal shavings in the oil. Yanked the hub, all bearings look good, but the hub clutch has gouges around the backside, however, all seemed to be working properly with the clutch itself.
However, the armature plate doesnt fit super tight into the slots, how tight should it fit into it?
Secondly, how hard should the armature plate stick to the magnet? It stuck but i was still able to peel it off by hand.
The passenger side isnt working either, at all, havent tore into that yet.
However, my speedo and AWD light is working, so i wouldnt think its electrical? But maybe? Ive been reading and reading and still cant really figure out WTF to check.
Im to the point of rebuilding both sets of hubs, but i dont wanna spend 200 bucks doing that if its a friggin wire somewhere.
DZG400 is offline
post #2 of 8 (permalink) Old 05-20-2018, 08:11 AM
stave7119's Avatar
In the how to section in the Technical discussions forum is a great thread on the hilliard clutches in the hubs. Goes through how it works and how to diagnose problems. There are photos and video with it. Great thread with lots of information!
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 8 (permalink) Old 05-20-2018, 08:42 AM Thread Starter
DZG400's Avatar
How do you get to the how to section?
DZG400 is offline
post #4 of 8 (permalink) Old 05-20-2018, 09:21 AM
stave7119's Avatar
Across the top of the page just under the Logo is a list across the page. HOME, FORUMS, ACTIVE TOPICS and so on. Click on the FORUMS and a drop down menu will appear. Click TECHNICAL DISCUSSIONS and off to the side another menu comes up with HOW TOs. Click on that and then in the top section you will see a thread titled ATV HUB STRUT HHILLIARD CLUTCH....Open that and start reading. There are a lot of replies so it will take a while if you want to get through the whole thing. Information in the beginning is what you want to start with, but you can ask questions at the end if you don't find the answers you need. Most all of us with the older machines that have the Hub clutches are subscribed so someone will know the answer. Good luck with it! They are not complicated in practice and once you understand how they work they can be fairly simple to repair.
post #5 of 8 (permalink) Old 05-20-2018, 06:04 PM
If you have metal shavings then you need a total refurbishment...both sides. I'd go through both sides in detail clean, flush and replace everything with a wear mark. Always replace the armature plates. They are cheap and there's no reason not to if you're already in there.
polman500 is offline
post #6 of 8 (permalink) Old 05-21-2018, 04:24 AM Thread Starter
DZG400's Avatar
Kinda what i figured. Im going to order armature plates today. The metal shavings came off the back side of the clutch, almost like the cv nuts wernt tight enough and the fingers rotated around and tore the clutch up
DZG400 is offline
post #7 of 8 (permalink) Old 05-23-2018, 05:30 AM Thread Starter
DZG400's Avatar
Might be getting somewhere, the coil gap was way off, got it adjusted and it seems to be grabbing better, got new clutches and plates coming, hopefully this does it
DZG400 is offline
post #8 of 8 (permalink) Old 05-23-2018, 06:55 AM
Sounds like you're on the right track.
850 Front Diff 4WD Gulf550 ATV Repair and Maintenance 3 05-12-2018 03:48 PM
True 4wd vs High Perf 4wd afsigma21 ATV Purchasing and Price 15 11-30-2017 06:27 AM
Highlifter edition 1000 4wd issues GregJL725 ATV Repair and Maintenance 1 10-01-2017 06:01 PM
02 Sportsman 700 4WD issues 56napco Polaris Sportsman 4 09-11-2017 04:32 PM
98 425 magnum 4wd issues. Front left won't turn. Fordpickupjaybird Polaris Magnum 0 11-29-2015 01:48 PM
