2009 sportsman 500 ho (carb) tranny interchangeable with other years? - Polaris ATV Forum
post #1 of 3 (permalink) Old 06-23-2018, 08:32 AM Thread Starter
aldom's Avatar
Hi does anybody know for sure what years Polaris Sportsman 500 I can interchange my 2009 Sportsman 500 high output carb model transmission with?
aldom is offline
post #2 of 3 (permalink) Old 06-23-2018, 09:00 AM
Year Product Model Assembly
2010 ATV SPORTSMAN 500 HO DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - A10MH50AJ/AX/AZ (49ATVSHAFTOUTPUT08SP500)
2010 ATV SPORTSMAN 500 HO INTL DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - A10MH50FX/FF (49ATVSHAFTOUTPUT08SP500)
2010 ATV SPORTSMAN 500 EFI TRACTOR DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - A10MN50ET (49ATVSHAFTOUTPUT08SP500)
2010 ATV SPORTSMAN 500 HO DRIVE TRAIN, MAIN GEARCASE - A10MH50AJ/AX/AZ (49ATVGEARCASE09SP500)
2010 ATV SPORTSMAN 500 HO INTL DRIVE TRAIN, MAIN GEARCASE - A10MH50FX/FF (49ATVGEARCASE09SP500)
2010 ATV SPORTSMAN 500 EFI TRACTOR DRIVE TRAIN, MAIN GEARCASE - A10MN50ET (49ATVGEARCASE09SP500)
2010 ATV SPORTSMAN 500 HO DRIVE TRAIN, MAIN GEARCASE INTERNALS - A10MH50AJ/AX/AZ (49ATVTRANSINTL08SP500)
2010 ATV SPORTSMAN 500 HO INTL DRIVE TRAIN, MAIN GEARCASE INTERNALS - A10MH50FX/FF (49ATVTRANSINTL08SP500)
2010 ATV SPORTSMAN 500 EFI TRACTOR DRIVE TRAIN, MAIN GEARCASE INTERNALS - A10MN50ET (49ATVTRANSINTL08SP500)
2010 ATV SPORTSMAN 500 HO DRIVE TRAIN, SHIFT FORKS - A10MH50AJ/AX/AZ (4999200059920005D02)
2010 ATV SPORTSMAN 500 HO INTL DRIVE TRAIN, SHIFT FORKS - A10MH50FX/FF (4999200059920005D02)
2010 ATV SPORTSMAN 500 EFI TRACTOR DRIVE TRAIN, SHIFT FORKS - A10MN50ET (4999200059920005D02)
2009 ATV SPORTSMAN 500 HO DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - A09MH50AS/AX/AZ (49ATVSHAFTOUTPUT08SP500)
2009 ATV SPORTSMAN 500 EFI DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - A09MN50AN/AX (49ATVSHAFTOUTPUT08SP500)
2009 ATV SPORTSMAN 500 EFI TRACTOR DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - A09MN50ET (49ATVSHAFTOUTPUT08SP500)
2009 ATV SPORTSMAN 500 HO DRIVE TRAIN, MAIN GEARCASE - A09MH50AS/AX/AZ (49ATVGEARCASE09SP500)
2009 ATV SPORTSMAN 500 EFI DRIVE TRAIN, MAIN GEARCASE - A09MN50AN/AX (49ATVGEARCASE09SP500)
2009 ATV SPORTSMAN 500 EFI TRACTOR DRIVE TRAIN, MAIN GEARCASE - A09MN50ET (49ATVGEARCASE09SP500)
2009 ATV SPORTSMAN 500 HO DRIVE TRAIN, MAIN GEARCASE INTERNALS - A09MH50AS/AX/AZ (49ATVTRANSINTL08SP500)
2009 ATV SPORTSMAN 500 EFI DRIVE TRAIN, MAIN GEARCASE INTERNALS - A09MN50AN/AX (49ATVTRANSINTL08SP500)
2009 ATV SPORTSMAN 500 EFI TRACTOR DRIVE TRAIN, MAIN GEARCASE INTERNALS - A09MN50ET (49ATVTRANSINTL08SP500)
2009 ATV SPORTSMAN 500 HO DRIVE TRAIN, SHIFT FORKS - A09MH50AS/AX/AZ (4999200059920005D02)
2009 ATV SPORTSMAN 500 EFI DRIVE TRAIN, SHIFT FORKS - A09MN50AN/AX (4999200059920005D02)
2009 ATV SPORTSMAN 500 EFI TRACTOR DRIVE TRAIN, SHIFT FORKS - A09MN50ET (4999200059920005D02)
2009 MIL SPORTSMAN 500 HO MILITARY TACOM DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - M09MH50MX (49ATVSHAFTOUTPUT08SP500)
2009 MIL SPORTSMAN 500 HO MILITARY TACOM DRIVE TRAIN, MAIN GEARCASE - M09MH50MX (49ATVGEARCASE09SP500)
2009 MIL SPORTSMAN 500 HO MILITARY TACOM DRIVE TRAIN, MAIN GEARCASE INTERNALS - M09MH50MX (49ATVTRANSINTL08SP500)
2009 MIL SPORTSMAN 500 HO MILITARY TACOM DRIVE TRAIN, SHIFT FORKS - M09MH50MX (4999200059920005D02)
2008 ATV SPORTSMAN 500 HO DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - A08MH50AX/AZ (49ATVSHAFTOUTPUT08SP500)
2008 ATV SPORTSMAN 500 EFI SCANDINAVIAN DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - A08MH50SS/SQ (49ATVSHAFTOUTPUT08SP500)
2008 ATV SPORTSMAN 500 HO EFI DRIVE TRAIN, GEARCASE FRONT OUTPUT SHAFT - A08MN50AF/AN/AQ/AR/AS/AT/AW/AX (49ATVSHAFTOUTPUT08SP500)
2008 ATV SPORTSMAN 500 HO DRIVE TRAIN, MAIN GEARCASE - A08MH50AX/AZ (49ATVGEARCASE09SP500)
2008 ATV SPORTSMAN 500 EFI SCANDINAVIAN DRIVE TRAIN, MAIN GEARCASE - A08MH50SS/SQ (49ATVGEARCASE09SP500)
2008 ATV SPORTSMAN 500 HO EFI DRIVE TRAIN, MAIN GEARCASE - A08MN50AF/AN/AQ/AR/AS/AT/AW/AX (49ATVGEARCASE09SP500)
2008 ATV SPORTSMAN 500 HO DRIVE TRAIN, MAIN GEARCASE INTERNALS - A08MH50AX/AZ (49ATVTRANSINTL08SP500)
2008 ATV SPORTSMAN 500 EFI SCANDINAVIAN DRIVE TRAIN, MAIN GEARCASE INTERNALS - A08MH50SS/SQ (49ATVTRANSINTL08SP500)
2008 ATV SPORTSMAN 500 HO EFI DRIVE TRAIN, MAIN GEARCASE INTERNALS - A08MN50AF/AN/AQ/AR/AS/AT/AW/AX (49ATVTRANSINTL08SP500)
2008 ATV SPORTSMAN 500 HO DRIVE TRAIN, SHIFT FORKS - A08MH50AX/AZ (4999200059920005D02)
2008 ATV SPORTSMAN 500 EFI SCANDINAVIAN DRIVE TRAIN, SHIFT FORKS - A08MH50SS/SQ (4999200059920005D02)
2008 ATV SPORTSMAN 500 HO EFI DRIVE TRAIN, SHIFT FORKS - A08MN50AF/AN/AQ/AR/AS/AT/AW/AX (4999200059920005D02)
polman500 is offline
post #3 of 3 (permalink) Old 06-23-2018, 01:46 PM Thread Starter
aldom's Avatar
thanks a lot for the quick response !
aldom is offline
Service manuals cookies ATV Repair and Maintenance 1078 05-10-2019 05:40 AM
Polaris Front Diff Seal Kit Question rg567 ATV General Discussion 3 12-16-2017 04:12 PM
