2015 Sportsman etx barely will run, pops, stalls - Polaris ATV Forum
post #1 of 13 (permalink) Old 09-30-2018, 04:41 PM Thread Starter
PaYankee's Avatar
Hello,
I have a 2015 Sportsman etx 325cc that failed on me today. I was going down a trail and it just the engine bogged down and quit like the fuel was cut off.
It will fire back up but it is hard to keep it running. It will only get up to 2500 rpm while running like crap and you have to blip the throttle to get it there. It will only hold 2500 for a few seconds before dieing out. While it's trying to run like this the engine has a slight backfire popping noise and it shakes. Runs the same with air intake off. Runs the same with fuel tank cap off. Tried to run hours after it cooled down and it does the same thing. Will not move under its own power.
Suspecting a bad spark plug or tps, need advice.
Has fresh 93 octane gas. Ran 20 miles today before this happened.
Thanks all.
PaYankee is offline
post #2 of 13 (permalink) Old 09-30-2018, 05:00 PM
bp405's Avatar
Any codes?
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 13 (permalink) Old 10-01-2018, 07:15 AM
Probably the fuel pump went south
latebird is offline
post #4 of 13 (permalink) Old 10-02-2018, 03:03 PM Thread Starter
PaYankee's Avatar
No codes. Just put in a new spark plug. Does the same thing. Can't even get to run anymore. Fuel pump makes whiring noise on startup. Researched the fuel pump issue and found the info about the 570s, probably the same pump.
They have the same part no.
PaYankee is offline
post #5 of 13 (permalink) Old 10-04-2018, 08:38 AM
wenatchee's Avatar
Fuel pump.
wenatchee is offline
post #6 of 13 (permalink) Old 10-04-2018, 03:10 PM Thread Starter
PaYankee's Avatar
I ordered a new quantum fuel pump along with the 570 gas tank heat shield and right side panel close off kit.
PaYankee is offline
post #7 of 13 (permalink) Old 10-04-2018, 03:58 PM
wenatchee's Avatar
Hey PaYankee, I did a quantum pump also. 500 miles/1.5 years since. All good so far. I was thinking about the tank heat shield and close off panel, but haven't yet. Probably do it when the pump goes out again. Actually like the heat during winter time, not so much during the summer though.
post #8 of 13 (permalink) Old 10-04-2018, 04:11 PM
bp405's Avatar
My thoughts also!!! With the close off kit on the new 570-T we have it'll be interesting to see the difference between it and the 800 in the winter
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #9 of 13 (permalink) Old 10-20-2018, 05:42 AM Thread Starter
PaYankee's Avatar
I put the new fuel pump in and now the quad runs great!
PaYankee is offline
post #10 of 13 (permalink) Old 10-20-2018, 06:09 AM
Berserker's Avatar
I can't believe the state of Polaris. Is the whole industry this bad? This is a 3 year old machine. Granted I don't know the mileage.
Mine is 13 years old, and still going, other than ECM catching fire. Ha. Mine doesn't leave property much, and miles are extremely low. My kaw SXS 2800 miles, has leaked and now using oil. I am still dissapointed with it, being only 7 years old.
I would think this forum would lean harder to the old machines, like mine or older, due to age. But it sure weighs hard to last few year, or less.
Lot of people take these deep off trails with miles to walk out, with no cell reception. I understand the later may bother you more.
Berserker is offline
Service manuals cookies ATV Repair and Maintenance 1085 Yesterday 04:36 AM
Part number for factory winch, 2013 sportsman 500 HO? Smokinu454 ATV Gear and Gadgets 4 11-28-2017 05:38 AM
