Best place to get that key is the dealer. Take your old one and he uses the numbers on it to get you the one you need. Key makers don't have the blanks.....that's my experience on that. Differentials oils are separate as is the engine and transmission oils are separate. I put the winch on mine but I used a different front bumper. Also installed new winch on my 2012. I have not had any experience with Harbor Freight winch. Was told it would not hold up. Out by myself needing a winch is not the place to find the winch is not any good. I used a 3500 Super Winch. Love it. I have the manual but not sure if it is available on line for free. No transmission oil filter. Hope I have helped.
Gret thx for all the quick responses...I did see an online manual...It mentions " front hubs oil"....is there lubes to change on these too ? Maybe I was in the wrong year ??
Also where do I get the plate mentioned above to mount the winch ?
Do you have the engine running when using the winch ??
Thxagain
Google for a manual.
Visit Polaris' lubricants charts website for correct lubes. Your 2002 uses gear oil in the front. Tranny oil all the rest. Engine oil for the engine. Demand Drive in the front wheel hubs.
Key blanks can be ordered on ebay or from any Polaris vendor and cut at the hardware store.
Winch and mount plate is buyer's choice.
Ok I’m confused.. the oil chart shows the following
Engine oil , gearcase lube transmission, angle drive fluid 4 oz front ( I assume for the diff ?), front drive fluid demand drive ( I assume for the hubs??)so must be there is NO rear diff it’s just the tranny gearcase lube ??
Also no rear hub lube ??
Would online be the cheapest place to get all the fluids
Allen screw on side of hub. Screw should be at 3 o'clock...to check. if oil comes out or is present..good or fill til oil comes out level at this point. Use on demand hub oil.. available at dealership,
For real ?? You guys would use Walmart oils ?? How would I know what to get for the front diff, hubs, rear tranny ?,,,,
Also they guy just changed the oil, used a fram filter and 0w40 Mobil 1....is this ok ??
Also is there a fuel filter on this ??
He said he did all the fluids and belt last spring
Just WHERE would you get oil? Walmart doesn't make the oil they sell and neither does Polaris or Honda or Yamaha or CanAm or any of the other various vehicle manufacturers!
For real I would!!! You do know Walmart doesn't manufacture the oils correct?!?!? I bet the previous owner bought the Mobil1 and Fram filter from Walmart. Yes thats fine what he did. A lot of guys use 0W-40 Mobil1.
I know Walmart doesn’t make oil.. zeeez..but many times manufactures have special additives ... so what would Walmart carry I should use for tranny fluid, front diff, front hubs ?
FYI I’m driving a 2000 Buick with almost 210k miles... all with Walmart brand oil ... which I believe is Quaker State...
I guess I should have asked for the cross references
Nobody even suggested using Walmart branded oil. Walmart sells most all the premium brand oils you can buy at any other place. Only the price is better.
I've put over 400,000 miles on three different Toyota trucks using oil and filters from Wally World. Pennzoil was always my preference for my Tacomas. They never had a drop of Toyota branded oil put in them other than what came in them new.
Ok here’s what the charts show for fluids ;
Tranny/ rear end...AGL
Front drive diff Angle Drive Fluid
Hubs use Demand Drive fluid
Now maybe I’m reading this wrong but it says “ front drive fluid” demand drive then below it hubs.
Then says “angle drive fluid” 4 oz front... so that’s the front diff ?? Only 4 ounces ??
CVCMAN, I suggest that you just go to a local Polaris dealer. Give them the year make and model and leave it to them to guide you with all this information. I'm not saying have them do the work for you but have them guide you with what you need for all of this. 1 - you will have all the correct material you need, 2 - you really won't be paying much more if any for their recommended products and 3 - if something isn't right when you do the maintenance you can hold them accountable. Just a suggestion.
113.4K members
