700 Twin Over Charging (20V +) - Polaris ATV Forum
 2Likes
post #1 of 15 (permalink) Old 12-07-2018, 07:51 PM Thread Starter
TimWeb's Avatar
Hello everyone. I have a Polaris Sportsman 700 Twin that has an issue over charging the battery. I have replaced the battery and voltage regulator/rectifier with a new one and still have the problem. It has the original CDI/Ignition box and possibly the original stator. If I disconnect the V reg, the reading doesn't change. Still 20V +. Can anyone help?
TimWeb is offline
post #2 of 15 (permalink) Old 12-08-2018, 03:31 AM Thread Starter
TimWeb's Avatar
Forgot to put the year. It’s a 2002.
TimWeb is offline
post #3 of 15 (permalink) Old 12-09-2018, 02:24 PM
Mike42's Avatar
Sounds like you got a bad regulator where did you get it from?
Mike42 is offline
post #4 of 15 (permalink) Old 12-09-2018, 03:12 PM Thread Starter
TimWeb's Avatar
The Vreg checks out in a bench test and the thing is, so did the original one and the used replacement one I first tried. I ordered a new stator and hopefully that does it. I'll keep this chat updated but in the mean time, if anyone has any new incites, I would love to hear it.
TimWeb is offline
post #5 of 15 (permalink) Old 12-10-2018, 06:44 AM
MNDS's Avatar
With the voltage regulator disconnected It shouldn't charge at all, where is the battery getting that power from? Is the starter disengaging?
When i had a bad regulator on my old twin I would see 17.5 to 18 volts but never 20+, but that bike has the Kokusan ignition, maybe the Ducati ignitions have some different wiring to the battery.
If the starter was engaged it would at like a generator and overcharge the battery.
2017 Sportsman XP 1000
RJWC Exhaust
RVS Performance ECU flash
2004 Sportsman 600 Twin
MNDS is offline
post #6 of 15 (permalink) Old 12-10-2018, 09:38 AM Thread Starter
TimWeb's Avatar
Pretty sure the starter is not engaged while it’s running. And yes, it has the Ducati ignition
TimWeb is offline
post #7 of 15 (permalink) Old 12-10-2018, 10:44 AM
The starter cannot back feed the battery unless the solenoid sticks and if the solenoid sticks, the starter is going to run like it was designed to - that was the most improbable possibility I ever heard of
FPD218 likes this.
latebird is offline
post #8 of 15 (permalink) Old 12-10-2018, 11:43 AM Thread Starter
TimWeb's Avatar
I have ordered a new stator and hope that fixes it.
I appreciate all the comments and helpful hints. If anyone has any new suggestions I would love to hear them and I’ll post results when I install the new stator.
TimWeb is offline
post #9 of 15 (permalink) Old 12-21-2018, 07:45 PM Thread Starter
TimWeb's Avatar
New stator changed nothing.
On a positive note however, a friend came to help me and discovered that my multi meter was defective.
I purchased a new one and it appears the bike has been working normally all this time.
I feel pretty embarrassed by this final conclusion but I’m sharing the info so others may realize that it may not always be an issue with the bike but can be an issue with equipment as well.
Double check your tools every so often to avoid throwing money at something that is working perfectly. Cheers
TimWeb is offline
post #10 of 15 (permalink) Old 12-21-2018, 10:48 PM
bp405's Avatar
That sux about the meter !!! But on the bright side you're up and running with no issues .
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
06 700 twin EFI Idle diesel dave 04 ATV Repair and Maintenance 5 08-29-2018 09:16 AM
02 700 Twin Charging Issue thisdj1 ATV Repair and Maintenance 5 10-25-2017 12:06 PM
New atv isnt charging (sportsman 700) mansatv ATV Repair and Maintenance 4 07-17-2017 07:11 AM
2004 sportsman 700 twin questions Meyers Polaris Sportsman 1 07-17-2016 09:17 AM
Sportsman 700 Crankshaft Brawndo ATV Parts Wanted 2 06-07-2016 05:18 PM
