2005 sportsman 700 carburated reverse issue - Polaris ATV Forum
post #1 of 13 (permalink) Old 01-07-2019, 07:44 PM Thread Starter
Bluelinelife22's Avatar
I have a 2005 sportsman 700 non efi that won't engage 4x4 when and also when I dont press the override button. What could it be
Bluelinelife22 is offline
post #2 of 13 (permalink) Old 01-07-2019, 10:24 PM
Sounds like its working perfectly to me. Its not SUPPOSED to engage AWD if you don't press the override button in reverse.
polman500 is online now
post #3 of 13 (permalink) Old 01-07-2019, 10:28 PM Thread Starter
It's not engaging in reverse at all
post #4 of 13 (permalink) Old 01-08-2019, 02:27 AM
Scotiaboy's Avatar
I’d start with a fluid change in the front rear end and also the 2 plugged connections on the handle bar , make sure they are clean too and try that , it’s often simple things before the complicated ones
Scotiaboy is offline
post #5 of 13 (permalink) Old 01-08-2019, 03:08 AM
bp405's Avatar
So it goes in 4 wheel drive in H +L but not in R????
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #6 of 13 (permalink) Old 01-08-2019, 06:38 AM Thread Starter
Correct it works perfect in h or L but not reverse
post #7 of 13 (permalink) Old 01-08-2019, 06:39 AM Thread Starter
alright I will do you have a pic of which two plugs it is your talking about
post #8 of 13 (permalink) Old 01-08-2019, 09:12 AM
Scotiaboy's Avatar
Left handlebar , a bad connection there causes all kind of issues
post #9 of 13 (permalink) Old 01-08-2019, 05:35 PM Thread Starter
Oh ok I'll check it out thanks
post #10 of 13 (permalink) Old 01-08-2019, 05:50 PM
Phearless's Avatar
When you push the yellow button in reverse does the 4x4 show up on the cluster?
Phearless is offline
Service manuals cookies ATV Repair and Maintenance 1085 06-17-2019 04:36 AM
VIN - Sportsman 500 or 500 HO? das86turbo ATV Repair and Maintenance 7 01-02-2019 06:58 AM
