Carb Rebuild still dies with throttle applied. - Page 3 - Polaris ATV Forum
 5Likes
post #21 of 33 (permalink) Old 05-29-2019, 03:19 PM
ronbell2u's Avatar
Its this jet that is hidden that gives this issue you have. you can see the hole on one end I have in my finger but the other end is real tiny and will not even exist after ethanol sets for some time even with stabilizer. I have a 99 Sportsman and been there. Check it out. If you try to use a small torch tip cleaner it will ruin it. They are cheap from Polaris.
ID:	118123   Click image for larger version
freesample and HawkX66 like this.
1999 Sportsman 500
ronbell2u is offline
post #22 of 33 (permalink) Old 05-30-2019, 06:23 AM Thread Starter
freesample's Avatar
all jets are brand new in the carb. So the carb is extremely clean and I really do not think its the issue. I believe its a fuel flow issue based on what i found out last night and told earlier in the forum.
The flow from the pump to the carb was a trickle compared to the flow from the tank. The carb is starving for fuel, so this leads me to believe it is the fuel pump. The fuel line from the tank would not reached the carb directly to bypass the fuel pump to confirm its the issue, so I am picking up some fuel line today to confirm its the pump. Purchased a replacement pump on amazon this morning.
freesample is offline
post #23 of 33 (permalink) Old 05-30-2019, 06:56 AM
HawkX66's Avatar
How's the petcock? Verify flow before and after?
Semper Fi!
04 Sportsman 600 4x4
HawkX66 is offline
post #24 of 33 (permalink) Old 05-30-2019, 08:36 AM Thread Starter
freesample's Avatar
so my fuel lines go
Tank to petcock- flow great (but still not the size of the fuel line)
petcock to pump- did not check this
pump to carb - slow trickle
post #25 of 33 (permalink) Old 05-30-2019, 09:18 AM
HawkX66's Avatar
so my fuel lines go
I would definitely rule that out before swapping fuel pumps. Don't move on to the next part of the fuel circuit until you get what you expect out of what you're looking at. Petcocks gum up all the time. Not to say it couldn't be the fuel pump, but rule out a clogged petcock first.
Also, when are you seeing the trickle from the pump to the carb? From the pump it will only trickle at most unless it's running.
freesample likes this.
Semper Fi!
HawkX66 is offline
post #26 of 33 (permalink) Old 05-31-2019, 04:33 AM Thread Starter
freesample's Avatar
10.4 I will do that before changing the fuel pump. The slow trickle is when the atv is running at idle.
post #27 of 33 (permalink) Old 05-31-2019, 08:41 AM
SunShine01's Avatar
Id say you still have ethonol contamination in possibly your float, fuel pump or needle valve. Could be also your choke is not operating right ?
Ethonol is a killer to small parts. I use SeaFoam to combat this and I find it works head and shoulders over everything out there.
You also might wanna check your solenoid and its wires. My 04 had a corroded connection giving me periodic starting issues.
SunShine01 is offline
post #28 of 33 (permalink) Old 05-31-2019, 06:27 PM
Snowchaser's Avatar
Run it till it dies, then open the bowl drain screw. Should tell you real quick if the carb is running dry or not. Then would be float setting, partially plugged main jet, then follow back to pump. Make sure the crank case vac line to the fuel pump is good too. Messing with the carb and lines could have dislodged some crap in the lines or elsewhere and clogged something. If someone else already mentioned all this then feel free to ignore me and carry on. Been a long week.
'99 335 Sportsman
Snowchaser is offline
post #29 of 33 (permalink) Old 06-04-2019, 04:17 AM Thread Starter
freesample's Avatar
Negative. The fuel pump was bad, so installing the new pump fixed the flow to the carb. The ATV starts fine, but the carb now seems to be flooded with gas and runs extremely rough.
Put everything back to factory settings but am at a brick wall. Oh and now gas is flowing out of the float bowl when the petcock is turned on.
-new air intake/ filter
-all new jets (carb completely cleaned)
-all new fuel pump
-new fuel filter
shop may be my next course of action.
post #30 of 33 (permalink) Old 06-04-2019, 06:02 AM
HawkX66's Avatar
-all new fuel pump
-new fuel filter
Glad to hear you got the flow straightened out. Now pull your carb back off and make sure you set the float level according to spec. If you have a good needle and seat in there now it must not be adjusted correctly if it's flooding. It's allowing the gas to flow past the needle and seat which should be shutting off the flow when the bowl is full.
Semper Fi!
HawkX66 is offline
Common Carb Issues pfunk76 ATV Repair and Maintenance 117 03-30-2019 08:09 AM
2008 polaris sportsman 800 idles but dies when throttle is applied. Freshracingrc ATV Repair and Maintenance 6 02-16-2019 02:28 PM
2000 Polaris scrambler 500 throttle dies Hardyfoods Polaris Scrambler 2 11-02-2018 05:33 AM
2001 90 Sportsman Starts Runs Dies on Throttle Curtix ATV Repair and Maintenance 8 08-24-2018 12:18 PM
02 500 6x6 thumb throttle NYrancher ATV Repair and Maintenance 2 01-30-2018 07:05 AM
