Carb Rebuild still dies with throttle applied. - Page 4 - Polaris ATV Forum
 5Likes
post #31 of 33 (permalink) Old 06-05-2019, 05:56 AM
Lockjaw's Avatar
This is one of those situations where messing with stuff will bite you. If the quad ran fine last year, and then this year it doesn't, adjusting settings on the carb is NOT the solution. All this is simple, you need fuel, air, compression and spark.
Case in point. I ended up replacing my carb. I have gone through the hassle with a 3 wheeler i had, buying anything but the actual carb that goes on it. So in this case, I bought a used polaris OEM carb. Installed it after I cleaned it with carb cleaner and brake clean. Ran like crap. I used compressed air also. Blew out everything. Still crap.
I took it off, took all the jets out of it, and dunked in in the gunk carb cleaner, for a couple hours. Pulled it out, blew it out, sprayed it again, reinstalled all the new parts, and bam, started right up and runs flawlessly.
The person who said Ethanol gas is the issue is right. It attracts water, and then it mixes with the alchohol in there, and causes all sorts of issues. Just regular carb and choke cleaner, or brake clean will not dissolve this mess, you need something stronger. Ethanol treatment is basically a chemical that creates a sheen on top of the gas. It is not the end all be all. And once you get water mixed in with gas with ethanol, NO TREATMENT reverses it.
If you ride it every day, great, run whatever gas you want, if you don't, run only no ethanol. My quad sat in my garage all winter, cranked right up this spring. I only use no ethanol gas. And even when I use it only in my 2 stroke power equipment, I still have issues.
I would take the carb apart and soak every jet and the main body in carb cleaner for several hours, then put it back together and see what you have. Set everything back to stock.
Lockjaw is offline
post #32 of 33 (permalink) Old 06-06-2019, 04:56 AM Thread Starter
freesample's Avatar
Alright, so the ATV is up and running but i wouldn't say running perfect. I took the gas tank off, flushed it with new gas. I also blew air thru all the lines. took the carb apart again and cleaned everything and blew air thru all of that. It idles and I can give it gas and it doesnt die on me anymore. My only concern now is it seems to running rough. Is there a way to upload videos to this foruM?
Also thank for everyone's help that got me here!
freesample is offline
post #33 of 33 (permalink) Old 06-06-2019, 07:46 AM
HawkX66's Avatar
Running rough might be from the crap gas that was going through it before. How are your plugs? Wires? Could be that the ethanol basically shellacked your valves and that would take a few rips to burn off if you're able to. That stuff can really wreak havoc when allowed to sit untreated.
Semper Fi!
04 Sportsman 600 4x4
HawkX66 is offline
Common Carb Issues pfunk76 ATV Repair and Maintenance 117 03-30-2019 08:09 AM
2008 polaris sportsman 800 idles but dies when throttle is applied. Freshracingrc ATV Repair and Maintenance 6 02-16-2019 02:28 PM
2000 Polaris scrambler 500 throttle dies Hardyfoods Polaris Scrambler 2 11-02-2018 05:33 AM
2001 90 Sportsman Starts Runs Dies on Throttle Curtix ATV Repair and Maintenance 8 08-24-2018 12:18 PM
02 500 6x6 thumb throttle NYrancher ATV Repair and Maintenance 2 01-30-2018 07:05 AM
