Rear Brake Caliper Fitting - Polaris ATV Forum
post #1 of 7 (permalink) Old 05-20-2019, 10:23 AM Thread Starter
HawkX66's Avatar
The rear brake caliper for my 04 Sportsman 600 showed up today. It came with banjo fittings instead of flared fittings. Is that the way they're supposed to be? Mine are flared fittings. I looked around on line and all I'm seeing are banjo fittings. I'd rather not have to buy adapters if I don't have to.
Thanks.
Semper Fi!
04 Sportsman 600 4x4
HawkX66 is offline
post #2 of 7 (permalink) Old 05-20-2019, 11:54 AM
Yeah, most of the newer machines use banjo fittings and its hard to find the reasonably priced ones that will work with the flared lines.
polman500 is online now
post #3 of 7 (permalink) Old 05-20-2019, 12:34 PM
The OEM caliper has inverted flare ports
Let us know where you find an adapter - I could find male pipe to inverted flare (would adapt your line to thread into a pipe threaded hole), male pipe to flare, inverted flare to female pipe (adapt the line you have to connect to a pipe nipple), a banjo to flare (adapt a banjo fitting to a standard flare fitting), a banjo bolt with a female pipe thread for a pressure brake light switch, but I could not find a banjo to female inverted flare.
You might just need a custom brake line.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #4 of 7 (permalink) Old 05-21-2019, 02:23 AM Thread Starter
HawkX66's Avatar
It turns out some of the relatively cheap calipers have both the banjo fitting as well as the flare. You have to read the fine print. Of course, mine didn't... I didn't bother going any further and just rebuilt my caliper. All is right with the world now... If I went the route of getting an adapter fitting, an -AN fitting probably would have worked fine. One of the seals in my caliper was missing a section about 1/2" long...
Semper Fi!
HawkX66 is offline
post #5 of 7 (permalink) Old 05-21-2019, 04:51 AM
Sounds good Hawk. You should be getting in pretty good shape now for work and play.
post #6 of 7 (permalink) Old 05-21-2019, 04:54 AM
On your tranny issue, did you ever try taking the linkage loose at the bell crank and see if you can put it in gear manually? If it'll go in that way you probably just need to adjust the linkage a little.
post #7 of 7 (permalink) Old 05-21-2019, 04:57 AM Thread Starter
HawkX66's Avatar
I haven't messed with that yet. I'm expecting that one to be more involved so I'm procrastinating a little... I'll probably mess with the linkage this weekend though just to see.
Semper Fi!
HawkX66 is offline
Service manuals cookies ATV Repair and Maintenance 1085 06-17-2019 04:36 AM
2011 Sportsman 500 HO Replacement Seat Cover CERVY ATV Visual & Body Modifications 6 05-14-2019 09:46 AM
Questions about 2008 sportsman 500 HO interchangeability Jfreeman531 ATV General Discussion 3 02-10-2019 04:03 PM
Compatibility matt1932 Polaris Scrambler 1 07-11-2018 08:49 AM
