01 sportsman 500 camber issues... - Polaris ATV Forum
post #1 of 3 (permalink) Old 05-21-2019, 12:57 PM Thread Starter
DZG400's Avatar
What would cause the front camber to be all out of wack? Both tires have the top kicked out with the bottoms tucked in. Not sure if this is negative or positive camber.
Either way...what would cause this? All the a arm bushings look good, i was going to blame the ball joints, but seeing as how it only has a lower joint id think it would make the tires tilt the other way...
Maybe im wrong.
I do have a set of springs in the front off a newer (05 i believe) 800 polaris....could that be causing this?
Any help is apperciated.
DZG400 is offline
post #2 of 3 (permalink) Old 05-21-2019, 02:35 PM
Absolutely - raising the front end will change the camber, so will lowering
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #3 of 3 (permalink) Old 05-22-2019, 04:52 AM Thread Starter
DZG400's Avatar
I was wondering but wasnt sure. I know IFS on a car can be raised without camber change (unless youre dealing with an old twin i beam ford) so figured this was the same.
So is there any decent priced 500 front springs that are heavy duty? Im 300lbs plus i plan on adding a winch and plow.
DZG400 is offline
flywheel hartman528 ATV Parts Wanted 3 06-13-2019 09:37 PM
Polaris Ground Cable Lenght Hondov65 ATV General Discussion 3 02-06-2019 08:46 AM
VIN - Sportsman 500 or 500 HO? das86turbo ATV Repair and Maintenance 7 01-02-2019 06:58 AM
sportsman rear facing "work light" swamped ATV General Discussion 4 03-01-2018 04:09 AM
Hub strut compatability sniper4x4 ATV Brakes & Suspension 3 04-05-2016 07:24 AM
