Electrical issue - Polaris ATV Forum
post #1 of 5 (permalink) Old 05-21-2019, 06:32 PM Thread Starter
davis911s's Avatar
Electrical issue
So I drive my 2012 Polaris 500 Sportsman tonight for about 20 minutes. Ran great, tach on dash was working when I pulled it into the garage. However I tried to start it about 10 minutes later and NOTHING. No starter, no lights, no dash....nothing. I tried everything below with gear shifter in Park AND in neutral
I checked battery and it is 12.8 volts. connections are tight.
I unplugged the 6 pin connector on the ignition, and using a multimeter I had no power to ANY of the lines. So I am missing something between battery and the ignition switch.
My initial guess is there must be a fuse somewhere between the battery and the ignition switch. Can someone please show me where the fuse would be.
Also on the 6 pin connector, which of the wires is always hot (12V)? I would love to know what each of the 6 wires is for, that way I could trace them back and find the issue
Thanks in advance, this is frustrating me because to me it looks like it should be a simple fuse or wire disconnected, but I can't see where fuse would be blown
davis911s is offline
post #2 of 5 (permalink) Old 05-22-2019, 05:23 AM
The yellow wire at the key switch is from the fuse block - it's hot unless the fuse (position 2 - 20 amp) is blown when the switch is turned to the on position, yellow connects to the red wire with the black stripe.
The r/b wire goes to the LH handlebar switch where the r/b is connected to the red wire with the white stripe when the engine stop switch is in the run position - from there is goes to the lights and all else.
Is the 20 amp fuse blown?
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is online now
post #3 of 5 (permalink) Old 05-22-2019, 10:26 AM Thread Starter
davis911s's Avatar
Stupid question
My quad has carbs. Where is the fuse panel? Is it under the access in the front by the yard?
post #4 of 5 (permalink) Old 05-22-2019, 11:03 AM
Yes - it's under the front access panel
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
post #5 of 5 (permalink) Old 05-26-2019, 07:12 PM
SunShine01's Avatar
I own your carbon copy bike. Flip your stow and lock front box. Youíll see a fuse panel.
I also have a 400 which is the same bike and had your issue. Wonít hold the factory fuse which was 20 amp. I bumped it up to 30 and itís fine.
I gotta figure out WHY it blows fuses but havenít had the time.
SunShine01 is offline
Over voltage Keith338 ATV Repair and Maintenance 31 06-06-2019 07:52 AM
NGK plugs Happyman Polaris Sportsman XP 1000 36 04-17-2019 05:00 AM
Any Polaris deep parts connections? TDMax Polaris Sportsman XP 1000 10 02-09-2019 09:13 AM
Polaris Ground Cable Lenght Hondov65 ATV General Discussion 3 02-06-2019 08:46 AM
Ignition switch 570 sportsman Fivespeed ATV New Members 4 12-15-2017 07:03 AM
