07 Polaris Sportsman no fuel - Polaris ATV Forum
post #1 of 3 (permalink) Old 09-21-2019, 04:11 AM Thread Starter
Antlerman9@gmail.com's Avatar
I have an 07 Polaris Sportsman 700
It sat for a while. Bought a new battery, replaced plugs, finally got it to start by putting a gas soak towel in the airline just below carb. When I pull the rag out it dies immediately. I drained the gas replaced w/ fresh and added a little sea foam. Any ideas?
post #2 of 3 (permalink) Old 09-21-2019, 05:27 AM
stave7119's Avatar
Fuel pump, Carb needs cleaned because the needle valve is stuck, fuel filter plugged.....Probably just the carb needs cleaned......If it sat with fuel in it the fuel degrades and bad things happen inside the carb. Pull it off and give it a good cleaning.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is online now
post #3 of 3 (permalink) Old 09-21-2019, 08:03 AM
The 07 700 is fuel injected - fuel pump is probably either stuck or otherwise not functioning - drain and flush the fuel tank, test and or replace the fuel pump - if still no go, take it to a dealer for diagnostics
latebird is offline
