speed sensor 2001 sportsman 500 - Polaris ATV Forum
post #1 of 3 (permalink) Old 09-21-2019, 11:59 AM Thread Starter
wentzele's Avatar
I need to replace my speed sensor on the 2001 sportsman 500 HO.
I see there are many models available but I am thinking that most use the same sensor just different connectors on the end wires. I see a 4011640 sensor looks the same as far as the actual sensor just a different connector then the one called out as direct replacement. Has anyone any experience with which ones but be swapped if I change the connector?
wentzele is offline
post #2 of 3 (permalink) Old 09-22-2019, 05:39 AM
The sensor you need is part # 4010298
It was used on the following models:
2000 325 MAGNUM 2X4 HDS (A00CB32FA) - Handlebar A00cb32aa
2000 325 MAGNUM 4X4 HDS (A00CD32FA) - Handlebar A00cd32aa
2000 325 MAGNUM 4X4 HDS II (A00CD32FB) - Handlebar A00cd32aa
2000 500 MAGNUM 4X4, HDS (A00CD50FA) - Handlebar & Headlight Pod A00cd50aa
2000 500 MAGNUM 4X4, HDS II (A00CD50FB) - Handlebar & Headlight Pod A00cd50aa
2000 DIESEL (A00CH46CA) - Handlebar & Headlight Pod
2000 INT'L BIG BOSS (A00CL50DA) - Handlebar & Headlight Pod A00cl50aa
2000 MAGNUM 325 2X4 (A00CB32AA) - Handlebar
2000 MAGNUM 325 2X4 (A00CB32CA) - Handlebar A00cb32aa
2000 MAGNUM 325 4X4 (A00CD32AA) - Handlebar
2000 MAGNUM 325 4X4 (A00CD32CA) - Handlebar A00cd32aa
2000 MAGNUM 500 (A00CD50AA) - Handlebar & Headlight Pod
2000 MAGNUM 500 EB (A00CD50AB) - Handlebar & Headlight Pod A00cd50aa
2000 SPORTSMAN 335 (A00CH33AC) - Handlebar & Headlight Pod
2000 SPORTSMAN 335 (A00CH33AD) - Handlebar & Headlight Pod A00ch33ac
2000 SPORTSMAN 335 (A00CH33AE) - Handlebar & Headlight Pod A00ch33ac
2000 SPORTSMAN 335 (A00CH33AF) - Handlebar & Headlight Pod A00ch33ac
2000 SPORTSMAN 335 (A00CH33AG) - Handlebar & Headlight Pod A00ch33ac
2000 SPORTSMAN 500 (A00CH50AA) - Handlebar & Headlight Pod
2000 SPORTSMAN 500 (A00CH50AB) - Handlebar & Headlight Pod A00ch50aa
2000 SPORTSMAN 500 (A00CH50AE) - Handlebar & Headlight Pod A00ch50aa
2000 SPORTSMAN 500 (A00CH50AF) - Handlebar & Headlight Pod A00ch50aa
2000 SPORTSMAN 500 (A00CH50AH) - Handlebar & Headlight Pod A00ch50aa
2000 SPORTSMAN 500 (A00CH50AK) - Handlebar & Headlight Pod A00ch50aa
2000 SPORTSMAN 500 (A00CH50AL) - Handlebar & Headlight Pod A00ch50aa
2000 SPORTSMAN 500 (A00CH50EB) - Handlebar & Headlight Pod A00ch50aa
2000 SPORTSMAN 500 RSE (A00CH50AC) - Handlebar & Headlight Pod A00ch50aa
2000 SPORTSMAN 500 RSE (A00CH50AJ) - Handlebar & Headlight Pod A00ch50aa
2000 SPORTSMAN 6X6 (A00CL50AA) - Handlebar & Headlight Pod
2000 XPEDITION 425 (A00CK42AA) - Handlebar & Headlight Pod
2000 XPEDITION 425 (A00CK42AB) - Handlebar & Headlight Pod A00ck42aa
2000 XPLORER 400 (A00CG38CA) - Handlebar & Headlight Pod
2001 325 MAGNUM 2X4 HDS (A01CB32FC) - Handlebar A01cb32aa
2001 325 MAGNUM 4X4 HDS (A01CD32FB) - Handlebar A01cd32aa
2001 500 MAGNUM 500 HDS (A01CD50FB) - Handlebar & Headlight Pod A01cd50aa
2001 DIESEL (A10CH46CA) - Handlebar & Headlight Pod
2001 INT'L BIG BOSS 6X6 (A01CL50DA) - Handlebar & Headlight Pod A01cl50aa
2001 MAGNUM 325 2X4 (A01CB32AA) - Handlebar
2001 MAGNUM 325 2X4 (A01CB32AB) - Handlebar A01cb32aa
2001 MAGNUM 325 4X4 (A01CD32AA) - Handlebar
2001 MAGNUM 325 4X4 MOSE (A01CD32AB) - Handlebar A01cd32aa
2001 MAGNUM 500 (A01CD50AA) - Handlebar & Headlight Pod
2001 SPORTSMAN 400 (A01CH42AA) - Handlebar & Headlight Pod
2001 SPORTSMAN 400 (A01CH42AB) - Handlebar & Headlight Pod A01ch42aa
2001 SPORTSMAN 400 (A01CH42AC) - Handlebar & Headlight Pod A01ch42aa
2001 SPORTSMAN 500 DUSE (A01CH50AD) - Handlebar & Headlight Pod
2001 SPORTSMAN 500 DUSE HO (A01CH50AF) - Handlebar & Headlight Pod A01ch50aa
2001 SPORTSMAN 500 HO (A01CH50AA) - Handlebar & Headlight Pod
2001 SPORTSMAN 500 HO (A01CH50AB) - Handlebar & Headlight Pod A01ch50aa
2001 SPORTSMAN 500 HO (A01CH50AE) - Handlebar & Headlight Pod A01ch50aa
2001 SPORTSMAN 500 HO (A01CH50AK) - Handlebar & Headlight Pod A01ch50aa
2001 SPORTSMAN 500 RSE HO (A01CH50AJ) - Handlebar & Headlight Pod A01ch50aa
2001 SPORTSMAN 6X6 (A01CL50AA) - Handlebar & Headlight Pod
2001 WORKER 500 (A01CH50EB) - Handlebar & Headlight Pod A01ch50aa
2001 XPEDITION 425 (A01CK42AA) - Handlebar & Headlight Pod
2001 XPEDITION 425 (A01CK42AB) - Handlebar & Headlight Pod A01ck42aa
2001 XPEDITION 425 (A01CK42CA) - Handlebar & Headlight Pod A01ck42aa
2002 325 MAGNUM 2X4 HDS (A02CB32FC) - Handlebar A02cb32aa/Ab/Fc
2002 325 MAGNUM 4X4 HDS (A02CD32FB) - Handlebar A02cd32aa/Ab/Ac/Fb
2002 500 MAGNUM VL HDS (A02CD50FB) - Handlebar & Headlight Pod A02cd50aa/Ab/Fb
2002 ATV PRO 500 4X4 PPS (C02CD50AC) - Handlebar & Headlight Pod
2002 INT'L BIG BOSS 6X6 (A02CL50DA) - Handlebar & Headlight Pod A02cl50aa/Da
2002 LUH 6X6 PPS (C02CL50AB) - Handlebar & Headlight Pod
2002 MAGNUM 325 2X4 (A02CB32AA) - Handlebar /Ab/Fc
2002 MAGNUM 325 2X4 (A02CB32AB) - Handlebar A02cb32aa/Ab/Fc
2002 MAGNUM 325 4X4 (A02CD32AA) - Handlebar /Ab/Ac/Fb
2002 MAGNUM 325 4X4 (A02CD32AB) - Handlebar A02cd32aa/Ab/Ac/Fb
2002 MAGNUM 325 4X4 FREEDOM (A02CD32AC) - Handlebar A02cd32aa/Ab/Ac/Fb
2002 MAGNUM 500 (A02CD50AA) - Handlebar & Headlight Pod /Ab/Fb
2002 MAGNUM 500 2X4 HDS (A02CB50FC) - Handlebar
2002 MAGNUM 500 RMK (A02CD50AB) - Handlebar & Headlight Pod A02cd50aa/Ab/Fb
2002 SPORTSMAN 400 (A02CH42AA) - Handlebar And Headlight Pod
2002 SPORTSMAN 400 (A02CH42AB) - Handlebar And Headlight Pod A02ch42aa
2002 SPORTSMAN 400 (A02CH42AC) - Handlebar And Headlight Pod A02ch42aa
2002 SPORTSMAN 500 ALL OPTIONS (A02CH50) - Handlebar And Headlight Pod All Options
2002 SPORTSMAN 6X6 (A02CL50AA) - Handlebar & Headlight Pod /Da
2002 SPORTSMAN 700 (A02CH68AA/AB/AC/CA/CB) - Handlebar And Headlight Pod
2002 XPEDITION 425 (A02CK42AA/AB) - Handlebar & Headlight Pod
2003 500 MAGNUM 4X4 HDS (A03CD50FB) - Handlebar & Headlight Pod
2003 MAGNUM 330 2X4 (A03CB32AA) - Handlebar /Fc
2003 MAGNUM 330 4X4 (A03CD32AA/AB/AC/FB) - Handlebar
2003 SPORTSMAN 400 (A03CH42AA/AB/AC) - Handlebar And Headlight Pod
2003 SPORTSMAN 500 HO (A03CH50AA/AB/AC/AD/AE/AH/AJ) - Handlebar And Headlight Pod
2003 SPORTSMAN 600 (A03CH59AA) - Handlebar And Headlight Pod /Af/Ag
2003 SPORTSMAN 6X6 (A03CL50AA) - Handlebar & Headlight Pod
2003 SPORTSMAN 700 (A03CH68AA/AC/AF/AH/AL) - Handlebar And Headlight Pod
2004 A04CH42AA SPORTSMAN 400 (A04CH42AA/AE/AG) - Handlebar And Headlight Pod
2004 A04CH42AQ SPORTSMAN 400 (A04CH42AQ/AR/AS/AT/AV) - Handlebar And Headlight Pod
2004 A04CH50AA SPORTSMAN 500 (A04CH50AA/AC/AE/AG) - Handlebar And Headlight Pod
2004 A04CH50AQ SPORTSMAN 500 (A04CH50AO/AQ/AR/AS/AT/AV/AW/AX) - Handlebar And Headlight Pod
2004 A04CH59AF SPORTSMAN 600 (A04CH59AF/AH/AJ/AT/AV) - Handlebar And Headlight Pod
2004 A04CH59AK SPORTSMAN 600 (A04CH59AK/AL/AN/AQ/AW) - Handlebar & Headlight Pod
2004 A04CH68AC SPORTSMAN 700 (A04CH68AC/AF/AH/AJ/AT/AV) - Handlebar And Headlight Pod
2004 A04CH68AK SPORTSMAN 700 (A04CH68AK/AL/AN/AO) - Handlebar & Headlight Pod
2004 A04CH68AU/CU SPORTSMAN 700 (A04CH68AP/AQ/AU/CU) - Handlebar & Headlight Pod
2004 A04JD50AA ATP 500 4X4 (A04JD50AA/AB/CA) - Handlebar & Headlight Pod
2004 ATP 330 4X4 (A04JD32AA) - Handlebar
2004 MAGNUM 330 2X4 (A04CB32AA) - Handlebar /Fc
2004 MAGNUM 330 4X4 (A04CD32AA) - Handlebar /Ab/Ac/Fb
2004 SPORTSMAN 6X6 (A04CL50AA) - Handlebar & Headlight Pod
2005 ATP 330 4X4 (A05JD32AA) - Handlebar
2005 ATP 330 4X4 QUAD (A05JD32EA) - Handlebar
2005 ATP 500 4X4 (A05JD50AA) - Handlebar & Headlight Pod /Ab/Ac
2005 MAGNUM 330 2X4 (A05CB32AA) - Handlebar
2005 MAGNUM 330 4X4 (A05CD32AA) - Handlebar /Ab/Ac
2005 SPORTSMAN 400 (A05MH42AB) - Handlebar & Headlight Pod /Ag/Ah
2005 SPORTSMAN 500 HO/INTL (A05MH50AB) - Handlebar & Headlight Pod /Ac/Ag/Ah/Al/At/Fb
2005 SPORTSMAN 600 (A05MH59AK) - Handlebar & Headlight Pod /An
2005 SPORTSMAN 6X6 (A05CL50AA) - Handlebar & Headlight Pod
2005 SPORTSMAN 700 (A05MH68AK/AN/AD) - Handlebar & Headlight Pod
2005 SPORTSMAN 700 EFI (A05MH68AC) - Handlebar & Headlight Pod /As/At/Au/Aw
2005 SPORTSMAN 800 EFI (A05MH76AC/AU/AW) - Handlebar & Headlight Pod A05mh76ac/At/Au/Aw
2005 SPORTSMAN MV7 (A05MH68AP) - Handlebar & Headlight Pod
2005 TRAIL BOSS 330 QUADRICYCLE (A05CA32EA) - Handlebar
2006 MAGNUM 330 4X4 (A06CD32AA) - Handlebar /Ab/Ac
2006 SPORTSMAN 450 (A06MH46AA) - Headlight Pod & Speedometer A06mh46 All Options
2006 SPORTSMAN 500 EFI (A06MH50AQ) - Headlight Pod & Speedometer /Ax/Ay/Az/Al/At
2006 SPORTSMAN 500 EFI INTL (A06MH50FC) - Handlebar & Controls
2006 SPORTSMAN 500 HO (A06MH50AA) - Headlight Pod & Speedometer /Ab/Ad/Af
2006 SPORTSMAN 500 HO INTL (A06MH50FB) - Handlebar & Controls
2006 SPORTSMAN 6X6 (A06CL50AA) - Speedometer
2006 SPORTSMAN 700 (A06MH68AA) - Headlight Pod & Speedometer /Ad/Af
2006 SPORTSMAN 700 EFI (A06MH68AQ) - Headlight Pod & Speedometer /At/Ax/Ay/Az
2006 SPORTSMAN 800 EFI (A06MH76AL) - Headlight Pod & Speedometer /Aq/At/Ax/Ay/Az
2007 RANGER 4X4 700 EFI/LE (R07RH68AD/AG/AH/AK/AL/AO/AP/AW) - Strut, Front
2007 RANGER 700 EFI 6X6 (R07RF68AD/AF) - Strut, Front
2007 SPORTSMAN 450 (A07MH46AA/AZ) - Headlight Pod & Speedometer
2007 SPORTSMAN 500 EFI (A07MH50AB/AL/AQ/AX/AY/AZ/MN50AF/AN/AT/AY) - Headlight Pod & Speedometer
2007 SPORTSMAN 500 EFI INTL (A07MH50FC) - Headlight Pod & Speedometer
2007 SPORTSMAN 6X6 (A07CL50AA) - Speedometer
2007 SPORTSMAN 700 EFI (A07MH68AX/AY/AZ) - Headlight Pod & Speedometer
2007 SPORTSMAN 800 EFI (A07MH76AL/AQ/AX/AY/AZ/A2/MN76AF/AT/AY) - Headlight Pod & Speedometer
2007 SPORTSMAN 800 EFI INTL (A07MH76FA) - Headlight Pod & Speedometer
2008 RANGER 4X4 700 EFI CREW (R08WH68AG/AH/AK/AR) - Suspension, Front Strut
2008 RANGER 4X4 700 EFI/XP ALL OPTIONS (R08RH68) - Suspension, Front Strut All Options
2008 RANGER 6X6 700 EFI (R08RF68AD/AF/AZ) - Suspension, Front Strut
2008 SPORTSMAN 500 HO (A08MH50AX/AZ) - Electrical, Switches, Sensors & Ecm
2008 SPORTSMAN 6X6 (A08CL50AA) - Electrical, Switches & Sensors & Ecm
2009 RANGER 4X4 700 EFI CREW (R09WH68AC/AG/AH/AL/AR/AZ) - Electrical, Regulator, Relays, Sensors & Ecu
2009 RANGER 6X6 700 EFI (R09RF68AF/AR/AZ) - Suspension, Front Strut
2009 SPORTSMAN 500 HO (A09MH50AS/AX/AZ) - Electrical, Switches, Sensors & Ecm
2010 SPORTSMAN 500 HO (A10MH50AJ/AX/AZ) - Electrical, Switches, Sensors & Ecm
2010 SPORTSMAN 500 HO INTL (A10MH50FX/FF) - Electrical, Switches, Sensors & Ecm
2010 SPORTSMAN 800 EFI (A10MH76AJ/MN76AX/AZ) - Electrical, Switches & Sensors & Ecm
SERIES 10 PTV 4X4 (C10CD50AA) - Handlebar & Headlight Pod
SERIES 10 PTV 6X6 (C10CL50AA) - Handlebar & Headlight Pod
latebird is offline
post #3 of 3 (permalink) Old 09-22-2019, 04:09 PM
Here's a link to a page full of the one you need rather than trying to make a different one work.
https://www.ebay.com/sch/i.html?_fro...10298&_sacat=0
polman500 is offline
