500 Replacement tire size - Polaris ATV Forum
 1Likes
post #1 of 29 (permalink) Old 10-07-2019, 03:29 PM Thread Starter
Spo307's Avatar
My tires soon will need to be replaced my question is can I put 26” tires For another inch of ground clearance is there any benefit?
Spo307 is online now
post #2 of 29 (permalink) Old 10-07-2019, 04:16 PM
cowanr's Avatar
Maybe I missed it in the sticky section cause I have the same question.
RC
cowanr is offline
post #3 of 29 (permalink) Old 10-07-2019, 04:23 PM
bp405's Avatar
Yes you can go to 26".
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #4 of 29 (permalink) Old 10-07-2019, 04:38 PM
Probably not unless you have or get aftermarket rims with more offset or put spacers on.
The problem is not the height of the tire. The problem is the width.
Your machine has a strut front suspension and 8" wide 25" tall OEM front tires.
All the 26" tall front tires I'm aware of are 9" wide. Depending on tire style and/or tire brand, 9" wide front tires will rub the tie rod ends and/or the strut unless you have rims with more offset or you add spacers.
polman500 is online now
post #5 of 29 (permalink) Old 10-07-2019, 08:22 PM
cowanr's Avatar
Thank you both for your reply's.
RC
cowanr is offline
post #6 of 29 (permalink) Old 10-08-2019, 04:46 AM
OP, I guess I should have said they MIGHT fit but it'll be close for the reasons given above. If the width will allow it without rubbing you're good. A lot depends on the particular tire you get.
I've seen some guys move the tie rod ends UNDER the attachment arm for clearance. It works but I never really liked that solution. 4+3 offset rims is how I put the big Pitbulls on my 800. Of course, when you do that you'll then need fender flares to keep the mud off you too.
Funny how atv mods keep adding up.
One mod leads to another which leads to another and another.... lol.
post #7 of 29 (permalink) Old 10-08-2019, 05:04 AM Thread Starter
Spo307's Avatar
So for 26x9 fronts i will need two 4+3 offset rims? What size front rim i have seen steel 4+3 offset
post #8 of 29 (permalink) Old 10-08-2019, 05:18 AM
bp405's Avatar
Yup those are the ones!! You're going to do all four corners with the Ito Delta steels??
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #9 of 29 (permalink) Old 10-08-2019, 11:03 AM
Yeah, you have to do all 4 or the front tires will stick out more than the rear.
post #10 of 29 (permalink) Old 10-08-2019, 11:10 AM Thread Starter
Spo307's Avatar
Probably just easier to replace stock size tires ☹️
