Slipping through water hole. - Page 2 - Polaris ATV Forum
post #11 of 14 (permalink) Old 02-07-2013, 08:08 AM Thread Starter
z5050z's Avatar
I was in low.
z5050z is offline
post #12 of 14 (permalink) Old 02-07-2013, 08:38 AM
Kevcules's Avatar
Good advice to remove the cover and take a peek. Probably needs a good cleaning and might as well change the belt. Sometimes age will damage the belts effectiveness so it's wise to replace it while your in there.
I use some die-electric grease all round my clutch cover and it seems to keep the water out just fine. I've been up to my seat in water and the belt never slipped. I don't go into water that deep if I can help it. Take a look at your crank seals inside the cover, I guess it's a good idea to silicone them in place to prevent water from coming in. Also your air breather snorkel connection should be greased and tightened(where it goes into clutch cover).....Good luck.
Kevin
2001 Sportsman 500 HO
2006 Honda Rincon 680
Famous saying......" I'm going to the garage" !
Kevcules is offline
post #13 of 14 (permalink) Old 02-07-2013, 09:45 PM
lost cause's Avatar
If you have a leak in the belt box, water will get in there, cause the belt to slip while in the water. Then when you get out of the water, the water will drain back out from wherever it is getting in, and your belt will start to grip again. Most likely you need to take the clutch apart, and seal behind the rear cover where it meets up with the engine/transmission. Do not use dielectric grease like the previous poster stated. I'm sure it was a typo, but dielectric grease is for your electrical connections. Silicon is used for sealing up the cover and snorkel connections. You are also going to need a new belt. OEM is highly recommended.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
lost cause is offline
post #14 of 14 (permalink) Old 02-08-2013, 03:46 AM
Kevcules's Avatar
lol......give me a little credit. I know what die-electric grease is for......I just used it around my clutch cover to keep water out and it's worked so far. The cover goes on easy and comes off easy. Silicone would be best but I don't want the mess when I remove the cover.
Kevin
Kevcules is offline
Need Help Stopping up water hole. UPINTHEHILLS Polaris Sportsman 16 09-20-2013 06:16 AM
2000 sportsman 500 fan wont comw on and water coming out of crankcaae at t water pump jasonlj72 ATV Repair and Maintenance 6 07-21-2012 03:54 AM
Oil leaking from water pump weep hole 800polaris ATV Repair and Maintenance 1 03-18-2012 09:25 PM
Hole in my rim... Makavel07 Polaris Sportsman 11 04-17-2011 03:39 PM
water and oil seals for water pump replacement fred398 ATV Repair and Maintenance 1 01-20-2011 04:41 PM
