2003 Sportsman 400, Overcharging and No Tach. - Polaris ATV Forum
post #1 of 4 (permalink) Old 02-08-2013, 02:06 PM Thread Starter
ColoradoRed's Avatar
Exclamation 2003 Sportsman 400, Overcharging and No Tach.
I have searched these forums well without results that seem to fit my ATV: a 2003 Non-EFI Sportsman 400.
It overcharges about 18V around 3K RPM and sits at 13V at idle.
The tachometer does not work, it did sporadically at idle when this first began to occur.
If I run at raised RPM for a minute or more the speedometer needle flashes and the battery icon flashes as well.
No other problems with the machine at all.
I am not sure if it is the stator, voltage regulator, or if it is the CDI box.
If anyone has heard of this before, or knows how to help please let me know; I do not have spare cash to trial-and-error this one.
ColoradoRed is offline
post #2 of 4 (permalink) Old 02-08-2013, 05:06 PM
Bruce! is offline
post #3 of 4 (permalink) Old 02-09-2013, 12:52 AM
4getful2's Avatar
Take the battery out of it first and have it load tested, a faulty battery will cause an overcharge. If the battery tests ok,then check the connections at the voltage regulator, if those are clean, then it's time for a new regulator..
4getful2 is offline
post #4 of 4 (permalink) Old 02-09-2013, 04:17 AM
creekman's Avatar
had this happen to my 04 sportsman 400. it was a bad voltage regulator.
creekman is offline
2003 500 overcharging i think xplorerman ATV Repair and Maintenance 1 02-25-2012 05:09 AM
2005 sportsman 400 overcharging porker ATV Repair and Maintenance 5 12-09-2010 06:19 AM
sportsman 700 overcharging JCarman ATV Repair and Maintenance 5 05-12-2010 11:53 AM
Help 06 sportsman tach will not work kellum410 ATV Repair and Maintenance 0 04-29-2010 07:58 PM
1999 sportsman 500 overcharging cavingoin ATV Repair and Maintenance 2 02-02-2010 07:26 AM
