2011 500 sportsman brake/neutral safety switch - Polaris ATV Forum
post #1 of 6 (permalink) Old 02-09-2013, 07:24 AM Thread Starter
musselmark's Avatar
I want to be able to start my 2011 500 without holding in the brake lever or putting it in neutral. My 2004.5 400 is this way from the factory. I can hear a switch click somewhere but haven't found it yet, if I bypass the switch and solder the wires together will the brake light be on all the time. Can someone explain how I could do this and where this switch is located. There are no wires go up the handle bar to the brake.
musselmark is offline
post #2 of 6 (permalink) Old 02-09-2013, 07:40 PM
bobx2's Avatar
Your question brings one word to mind. WHY!
2018 Polaris General 1000, Elka Stage 2 Shocks, 29" Tusk Warthogs, Polaris 4,500 lb. winch, Factory UTV Skid Plates, Dux Turn Signal/Horn Kit, EMP Cooter Brown Roof, Ryfab Folding Glass Windshield, Spring Brake Thingy
2015 Sportsman 570 Touring EPS, 26" Kenda Bearclaw HTR's on ITP Delta Steel wheels, Warn Vantage 3000, Elka Stage 1 Shocks, Warn Mid-Mount Plow (Wife's)
bobx2 is offline
post #3 of 6 (permalink) Old 02-10-2013, 03:05 AM Thread Starter
musselmark's Avatar
Well the choke on this machine is spring loaded and will not stay out, so it is almost impossible to turn the key, hold the choke out and hold the brake in at the same time. Yes I know I could put it in park, neutral or lock the brake on but it is just a pain in the arse especially when I am so used to just starting my older sportsman and going
post #4 of 6 (permalink) Old 02-10-2013, 05:09 AM
gvmax58's Avatar
I have a 2011 500 as well and the choke stays out by itself I think there is an adjustment on the choke knob to stiffen it up so choke does not retract when you let go of it. Hope this helps.
gvmax58 is offline
post #5 of 6 (permalink) Old 02-10-2013, 05:36 AM
jordaman17's Avatar
agreed with above, the tension of the choke can be set right on the light pod.
2016 Sportsman 450, Polaris front bumper, Powermadd Sentinel handguards, Runva 2500lb Winch, Two Auxbeam 4" LED Light Bars, Rubberdown Customs 1/4" wheel spacers on front, running on 26" Kenda Bearclaw htr's.
(SOLD November 5th,2017) 2010 Polaris Ranger 400, Super ATV Roof, running on 26" Maxxis Zilla's.
(SOLD August 17th, 2015) 5490km 2008 Polaris Sportsman 500 Ho, Polaris Hand & Thumb warmers, RotoPax 4 Gallon Fuel Pack, Custom Made Rear Bumper, PowerMadd Hand Guards, Polaris Rear Work Lights, Ricochet Ultimate Armor, Polaris 3500lb Winch, Rear Rack Extender, Polaris Brush Guard, 3 Headlight Mod, Uni Air Filter, EPI 'patv1' primary clutch spring, 25" Interco Swamplites!
Subscribe to my youtube channel! ---> http://www.youtube.com/user/mudsling...ew=0&flow=grid
jordaman17 is offline
post #6 of 6 (permalink) Old 02-10-2013, 08:04 AM
Greenrancher's Avatar
Agree with the tension comments. According to my 2011 manual, page 46:
"8. If the knob does not stay where positioned, increase the tension by rotating the tension adjusting nut clockwise."
Greenrancher is offline
needed transmission neutral switch indicator SteelNuts ATV Parts Wanted 0 01-21-2013 10:22 AM
Safety switch Ilikemud ATV General Discussion 1 08-01-2012 06:47 PM
Throttle safety switch bypass? islander83 ATV Repair and Maintenance 3 06-13-2012 03:27 PM
HELP! Sportsman 500 stalls when shifting from neutral to high and neutral to reverse. dt31906 ATV Repair and Maintenance 4 06-04-2011 08:52 AM
How to bypass neatral/park safety switch?? 07 Sportsman 500 PSD4life Polaris Sportsman 7 11-23-2009 07:24 PM
