05 500 ho awd not working - Polaris ATV Forum
post #1 of 5 (permalink) Old 01-21-2014, 06:49 PM Thread Starter
4jfarm's Avatar
I have a 2005 sportsman 500HO AWD
I have two issues
1) the AWD does not work, the light does not come on the indicator on the dash does not show what gear it is in ( Replaced Gear Indicator relay still nothing) changed the front diff. fluid. It will work in AWD if you use the manuel override button .
2) the top center light will not work replaced the bulb nothing, noticed I have power on both contacts
Just purchased this unit said it had a new ECU and replaced the left handlebar switch which made the dash work.
Thanks for your help.
Steve
4jfarm is offline
post #2 of 5 (permalink) Old 01-21-2014, 07:30 PM
Bruce! is offline
post #3 of 5 (permalink) Old 01-22-2014, 06:27 AM
GeeLeDouche's Avatar
Does your speedo work in this unit? I believe the speedo cluster is what controls the AWD. so if it isn't working then that's your problem.
About the headlight, have you hooked up a electrical tester to the light to see if its getting power? if it isn't, follow the wire down to the small waterproof pouch underneath the main headlight to the breaker switches and cut that sucker open and make sure it is still operating properly with a electrical tester. (There is a youtube video to show you how to check it)
GeeLeDouche is offline
post #4 of 5 (permalink) Old 01-22-2014, 09:33 AM Thread Starter
4jfarm's Avatar
Yes it has power, Infact it has power on both leads which I thing is not correct
4jfarm is offline
post #5 of 5 (permalink) Old 01-22-2014, 09:34 AM Thread Starter
4jfarm's Avatar
Yes the speedo does work
4jfarm is offline
EBS Not Working? partycove2 ATV Repair and Maintenance 7 02-26-2013 03:55 AM
AWD not working! bigT ATV Repair and Maintenance 4 01-12-2013 04:58 AM
fan not working!! 409scrambler4x4 Polaris Scrambler 2 11-03-2010 05:52 PM
AWD not working rckstr Polaris Sportsman 3 10-19-2010 04:20 PM
ADC not working??? H2O ATV Repair and Maintenance 5 12-10-2009 05:12 PM
