1996 sportsman 400 strut replacement - Polaris ATV Forum
post #1 of 2 (permalink) Old 01-22-2014, 10:19 AM Thread Starter
Neptugian's Avatar
Hello all,
I needed struts on my sportsman 400. I ordered a pair from a dealer off of ebay. I had a Polaris mechanic put them in to the tune of 500 dollars labor.
He said that the whole front body and fenders had to come off.
Turns out that the struts are bad. still slams open on every little bump. (good shock absorption but not dampening upon opening of the spring).
Is this a job that I can do myself without tearing the whole machine apart???They shouldn't be stuck in the hub since these were just placed recently.
Help with any tips or suggestions.
Thanks.
Bill
Neptugian is offline
post #2 of 2 (permalink) Old 01-22-2014, 11:27 AM
polaris_is4mud's Avatar
I'm 14 years old and before least spring I hadn't changed struts in a Polaris before in my life and all went well. Unfortunately to do it your going to have to remove all of the front bumper and rack, electrical cover and loosen the fenders near the floor boards and remove the bolts for the fender around the rad, then I used a stick to bend the fender up so I could get my ratchet on the top but of the shock assembly I then loosened those nuts and began disassembling the spring/shock assembly and removing it from the McPherson strut while the ATV was jacked up but beware that when you take off the top bolt for the shock assembly the a arm will drop down and my jack was set t9 high for one side and the bearing fell out inside the CV boot and that's a pain in the ass and costs an extra $25 so make sure to only jack up your ATV enough so the springs don't have any weight on them but the tires are touching the ground. It took me about 6 hours alone only because the bearings fell out and I had to find out what order to put the hub together.
polaris_is4mud is offline
96 xplorer 400 strut replacement sbishop664 ATV Repair and Maintenance 8 04-10-2019 09:00 AM
92 Trailboss 350 4x4 Front Strut Replacement Mountain638 ATV Brakes & Suspension 8 03-25-2013 04:10 PM
Strut replacement with HD springs mudbogger4x4 ATV Brakes & Suspension 2 02-14-2013 07:43 PM
Strut seal replacement 96 sportsman 400 brian0519 ATV Repair and Maintenance 6 11-11-2010 05:40 AM
Front Strut for 1996 Sportsman 400 18fisher Polaris Sportsman 8 06-24-2010 04:55 AM
